Question about Proscan 26LA30Q 26 in. LCD Television
Lost channels on proscan tv
Since the switch over to digital,I have lost some channels. I am being told that I need to delete the channels from memory. How is this done on a Proscan 26LA30Q. There is no answer in the manual and the manufacturer could not help.
  • 408 Answers
Press the menu button on your remote.  That should give you the main menu where you can go into add/delete channels and do an autoscan to only save channels that are good.
Posted on Mar 04, 2009
Proscan PLEDV 1945A-B will not recognize cable. Auto channel scan results in no channels found
Do you have the converter box to convert the incoming signal from digital to analog, you must have this to receive broadcasts.
Nov 04, 2016 | Proscan Televison & Video
I hooked up my new Proscan TV to the antenna but it can't find any channels
You need to check the connection is tight from the antenna and also on the back of the tv. You may need to try another coaxial cable. Is your antenna powered, meaning does it have a power plug that needs to be plugged in? Is your tv an old crt television? You may need a converter box to be able to view digital channels. A signal booster may help you get more channels.
Your tv or antenna may be defective. You could try your antenna on another tv. If your other tv gets a signal, your tv's tuner could be bad. If the other tv goes not get a signal either your antenna could be bad. I hope this helps narrow down your problem.
Oct 22, 2016 | Proscan Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Channels lost on starview box
Yeah i had the same problem with starview 4. i upgraded the firmware and still no good. i then by accident set the default key. it worked. i'm not sure if it will work for u.
Aug 30, 2009 | StarTech.com StarView SV211K 2-port KVM...
I just setup my 42" 1080p proscan tv I have Direct tv and can not get a signal.
Okay most settop direct TV boxes go into a coaxle connector in the back of your TV witch then your Tv would need to be on channel 3 make sure channel 3 is detected by autoscanning for it or undeleting it if its been deleted but make sure the direct tv box is on and running.
If you have them on the scant connectors make sure you on the right input on your TV control there should be a input button press that to scan through to find your direct tv box!
I hope this helps!
Jul 08, 2009 | Proscan 42LA45H 42 in. LCD TV
Proscan TV Instruction Need
you wont be able to the high with rabbit ears antenna you will catch the low free channel.you need the cable to get the high channel.so it is est to connect back your cable good luck
May 06, 2007 | Proscan PS32600 32" TV
Proscan 26LA30Q 26 in. LCD Television Logo
303 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
