Hi, if you mean network unlock, it is possible to unlock this phone model via USB on Fastgsm.com. It's also possible to get the unlocking code directly via IMEI, but that depends on what provider and country your phone is locked to.
SOURCE: nokia 5800 music xpress display problem
Sounds like the connection from the phone and ur touch screen is loose. Would suggest getting a technician to fix it. There are online resources that also show you how to do it.
SOURCE: lost security code to nokia 5310 xpress music
Dear user,
On the main screen , Press *#06# to get your IMEI
number,
Then just visit this website http://www.unlockme.co.uk/master.php?imei=354841017025585
And enter your IMEI code to get your Master code.
Your Master code will help you change your Security Code.
This website will help you alot.
Goodluck. :)
SOURCE: phone startup failed contact the retailer?
hi you should get your mobile flash at your retailer's as trying to doing this by your own may damage the phone ;)
SOURCE: hi, my nokia xpress music 5800 phone is blocked by
Call your sim service provider's customer care center, they will give you the PUK code instantly.
Please rate the answer. Thanks for using FixYa.
SOURCE: my nokia xpress music 5800
This can be caused by a lack of memory.
Please take a full back up of the phone and check if there is any new firmware updates available. This is possible through the OVI suite on the pc or by using the SW updates(if that is not present in the phone then dial *#0000#, and say options -> check for updates. THIS WILL REQUIRE A DATA CONNECTION).
The newer firmwares are known to have more free memory.
Also another suggestion would be to move message memory to the memory card.
This can be done by going to Messaging ->options -> settings ->other -> memory in use (change that to memory card)
