My 6500 series printer keeps saying there is a carrier jam and will not print.
  • wbcutch Mar 05, 2009
    The printer is a Lexmark 6500 series
  • 13,433 Answers
Reinsert the cartridges, and in the process that should unjam the carrier. also unplug and try again.
Posted on Mar 04, 2009
  • Ekse Mar 04, 2009
    Could you send me the brand and exact model please? there are a few printers from diffrent manufacturers that actually are 6500 series. You can use the add a comment link to send me this info.
    Thanks.
  • Ekse Mar 05, 2009
    To clear a carrier jam in this model of lexmark
    1. Raise the scanner unit
    2. Remove any objects blocking the path of the print cartridge carrier
    3. make sure the cartridge carrier lids are completely closed.
    4. close the scanner unit
    5. press ok or "v" type of button.
    6. If the problem is not solved, repeat the above steps, remove the cartridges from the carrier, close the lids without cartridges in them, continue, and press ok.
    7. Now repeat the above steps again and this time reinsert the cartridges into the printer. when done press ok again.
    Make absolutely sure there is noting on the way of the carrier.
HP 6500 Printer cartrige stuck on right side
unplug printer and plug the printer back in to see if it will try to initialize.
Jan 30, 2013 | Office Equipment & Supplies
I keep getting the message failed to create print object Lexmark 6500 series. The specified module could not be found. (126)
It coudl be a printer driver issue. Please follow the steps below to fix the problem.
First, uninstall your existing print driver. On your computer, go to Start menu > Programs > Lexmark 6500 Series > Tools > Uninstall. After the uninstall process, reboot pc when prompted.
Second, visit the Lexmark website to download and re-install the Lexmark X6500 printer driver. Select your operating system > download > execute the file. Follow the instructions on your computer screen.
Lastly, after the re-install process, try to print again to verify that the problem is fixed.
Sep 06, 2011 | Lexmark X6570 InkJet Printer
Our HP Deskjet 6500 wireless copier is stuck on copying 8.5 x 11 about 1/4 of the size smaller...shrunken copies, AH! How can we reset the copier. Thank you April
Thank you for posting your printer problem to FixYa.
  • On the document you want to print.
  • Go to FILE, PRINT (or PRINTER PROPERTIES)
  • The Print Dialog Box will open
  • Click the EFFECTS tab
  • Check the option that says Print document on:
  • Choose the correct paper size from the pull down menu
  • Uncheck the option that says Scale to fit.
Keep me posted.
Jas247
Aug 19, 2011 | HP Deskjet 6500 Series
I Got a dell printer and i don't know what to do and in the printer it says Clear Carrier Jam
Turn the printer on.
Lift the lid to expose the print-head mechanism.
The "carrier" is that part of the mechanism that moves the print-head across its range.
Something is physically blocking, or "jamming", that carrier.
Feb 25, 2011 | Dell V305 All-In-One InkJet Printer
When trying to print, it says I have a carrier Jam.
HI!! in your case my diagnose is that maybe the the incoder strip was defective and need to replace it.
Jul 12, 2009 | Lexmark P4350 All-In-One InkJet Printer
Not working see bottom
Check your entire feed to make sure there is NO paper jams. Sometimes even the smallest little piece of paper can get jammed up and can e hard to see.
You can also check your manual for diagnostic mode and alignment print page.
May 13, 2009 | Dell 926 All-In-One InkJet Printer
Lexmark 2400 has message saying clear carrier then press start
Good day Sir, Please check the power switch light if blinking.
  • power light blinking slow - printer is out of paper.
  • power light blinking fast - there is paper jam in paper.
  • once, pauses and blinks again - raise the scanner unit, and remove any objects blocking the path of the printer cartridge carrier. Or the print cartridge is missing/ not installed properly. Or the printer cartridge is not the correct type for the printer.
Have a nice day.
Nov 22, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
19 people viewed this question
k24674
jasbo
jasbo
