Question about Sony Ericsson W200i Cellular Phone
USB connection. My phone won't connect to my computer, it says it's connected (W200i) but it says the device can't start...HELP? D:
  • Anonymous Mar 10, 2009
    when i will connect my phone to computer it shows connected but im unable to transfer my files why?
    i dont have p c suite software frm where download it
  • 53 Answers
Its a simple virus fault u try unplugging and reconnecting few times
if tat doesnt work use some other usb
use a new fresh port that wil help
Posted on Mar 05, 2009
When i connect my sony ericsson w200i phone by usb data cable to laptop then it shows that usb device not recongized
Cell phones use the popular USB connection which sometimes produces errors while connecting. These messages are similar to the "Device Not Recognized" error received with various USB devices. Fixing a cell phone is sometimes specific to the brand, but they are so similar that most can be fixed the same troubleshooting steps.
instructions
Device Manager
Click "Start" and go to "Control Panel." Double-click "System" and locate the Hardware tab to find the Device Manager. Vista and Windows 7 users can just type "Device Manager' from the start menu.
Locate "Disk Drives" from the list and double-click "Portable Device." If there is an exclamation mark or other error on the device, go to the "Drivers" tab.
Click "Uninstall" and remove the player. Restart the computer and attach the player reinstall the drivers.
Anti-virus conflicts
Plug the player into a different computer to see if it gets recognized. If it does not, contact the manufacturer to find out if it is broken.
Turn off your anti-virus program on your PC if the device works on other computers. Reinstall the drivers using the device manager as described in section 1.
Plug in the player to confirm the connection.
Other solutions
Check the battery level and make sure the batter is not low or depleted. A low battery will sometimes prevent the player from connecting. Let it charge from the power cord, if necessary.
Verify that you have at least Service Pack 1 installed. Go to the Start menu and type "Run." Press Enter.
Type "Winver" in the box and press "Enter." The Windows version will be displayed along with any installed service packs. Download a service pack from Microsoft, if applicable.
Remove the player from the USB port and push a pin into the reset hole located on the bottom. Reconnect to see if the problem is resolved.
Check the connection to make sure it's secure. The cable should fit firmly into both the player and the computer. Connect to a different USB port if you have one available.
Tips & Warnings
A bad cable will sometimes prevent a good connection. Use a different one to isolate the cause.
Jul 23, 2011 | Sony Ericsson W200i Cellular Phone
Is my phone, sony ericsson w200i, able to connect internet usin pc?
you can connect your computer to the internet by using your phone, but you cant connect this phone to the internet using the computer's internet..
PLEASE RATE THIS ANSWER, IF YOU GET ANY HELP FROM THIS ANSWER OR LIKE THE ANSWER
Apr 06, 2011 | Sony Ericsson W200i Cellular Phone
When i connect my phone to the computer it says usb device not recognised and i cant get songs on to my phone
DON'T connect your phone to PC. First install SE PC Suite. When installed click on HOW TO CONNECT and follow on screen directions.
Oct 03, 2009 | Sony Ericsson W200i Cellular Phone
Have a sony w200i
It's easy to transfer music from your PC to your phone using the USB connection, which supports drag-and-drop data transfer. Likewise, transferring photos or videos from your phone back to your PC is straightforward. The W200i also supports an infrared connection, but not Bluetooth - with a phone this cheap there have to be some compromises!
Mar 17, 2009 | Sony Ericsson W200i Cellular Phone
How can access text messages to pc? or how i use pc suite4?
i have a w200 to... and it seems that Sony Ericsson has a problem with the PC suit and w200, i could not connect it...
did you try downloading My phone explorer?
try connecting it with this program, it is similar to the PC suit, but alot better...
as an alternative, you can allways turn your phone of, and connect it to your PC, it will be recognized as an USB device, and you can do anything you want :)
Feb 13, 2009 | Sony Ericsson W200i Cellular Phone
Infrared connectivity not happening
It is highly hard to connect two mobile through infrared!..make sure both the ports are in correct position then you will be able to transfer the data easily!..THank you!!..
Jul 17, 2008 | Sony Ericsson W200i Cellular Phone
System restarts
Shut down the phone before connecting to the PC, if you haven't already done so. Also try connecting the phone to the PC without the memory card in the phone. If the phone gets detected normally, then there's a problem with the memory card. If the computer still restarts, then you will need to take it to the SE service center.
Jun 16, 2008 | Sony Ericsson W200i Cellular Phone
Download photos from motorola W377
Did you installed Motorola USB driver?
May 25, 2008 | Motorola Mobility RAZR V3
Problem
bcoz u hav not installed software cd which is given with ur W200i phone first install in ur pc and then connect ur work is done!!!!
Feb 29, 2008 | Sony Ericsson W200i Cellular Phone
Sony Ericsson W200i Cellular Phone Logo
60 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
