Question about Ricoh Aficio SP-C210SF Printer
Our RICOH Aficio SP C210 SF printer says install transfer roller
Our RICOH Afficio SP C210 SF printer displays an error message after startup. It says ''NO TR, install transfer roller.'' The transfer roller is still intact. Why did it say the transfer roller can not be found?
  • Ricoh Master
  • 13,433 Answers
Try removeing the transfer roller, try without the roller, then place it back and try again. most likely a sensor problem.
Posted on Mar 04, 2009
  • Ekse Mar 04, 2009
    The sensor or switch that gets pressed or is enabled when the tr is properly installed is not being pressed or activated.
  • Ekse Mar 04, 2009
    Follow these steps:
    1. Turn off the machine's power switch. Unplug the telephone line cord first, and then unplug the power cord from the AC power outlet. Open the back cover of the machine.
    2. Clean the registration roller and the paper pick-up roller with a dry soft, lint free cloth to repvent paper jams
    3. Clean the transfer roller unit and the transfer roller guide
    4. Clean the exit roller. This will help to prevent paper jams at the paper exit and dirt from appearing on your printouts
    5. Close the back cover.
    6. Plug the machine's power cord back into the AC power outlet first, and then plug in the telephone line cord. Turn on the machine's power switch.
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
How do fix error Color registration could not performed
Possible remedies for weak images.
-Loose connection between transfer roller and high voltage supply unit.
-Dust in the laser beam path
-Transfer belt not contacting PCU.
Check the transfer unit.
Defective PCU. Replace the PCU.
Defective transfer roller. Repair the transfer roller.
Defective fusing unit. Replace the fusing unit.
Defective engine board. Replace the engine board.
Feb 02, 2016 | Ricoh Aficio SP C410DN Laser Printer
What does the error message C8 mean?
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Ricoh Aficio SP 100SU User Manual Error And Status Indicate On The Control...
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
Ricoh afficio mp 1600 "sc 559 " help me
This code is related to a jam in Fusing Unit.
First of all you need to repare that jam problem. (Probably a stripper pawl out of the place) and after that you can disable that message by in SP mode. The main problem is the jams. After that reply to me and i help you disable the message
Apr 22, 2011 | Ricoh Aficio MP 1600L Black and White...
My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Feb 18, 2010 | Ricoh Aficio SP C811DN Laser Printer
Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
Ricoh aficio sp c210 sf is printing with a black line on the right side of each page when used as a printer or copier.
you are having a drum or fuser issue, to find problem you will need to attempt to make copy and as paper passes the drum you need to open door and remove paper,if line can be rubbed away then it is drum if it cant then the fuser is problem
Apr 17, 2009 | Office Equipment & Supplies
Ricoh Aficio CL800 - Set Transfer Roller
possible transfer roller rotation sensor dirty or damaged transfer roller. check -- open rear door and see how the roller looks.
Apr 10, 2009 | Ricoh Aficio CL1000N Printer
Color bad on ricoh aficio sp c210 sf
Hi There,
print out a page from windows paint program of cyan, magenta, and yellow. see which colors are incorrect. that will help you get closer to the problem area.
the drum also may not be screwed in all the way. remove it, and try putting it back in again.
Dec 12, 2008 | Ricoh Aficio Colour 3006 Color Copier
Ricoh Aficio SP-C210SF Printer Logo
653 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
