Question about Kodak EasyShare Z612 Digital Camera
Please help!! My Easy kodak camera Z612 in about 2-3 years old. Im unable to get it to turn on, I have tried to replace the battery and that did not solve the problem. What should I do. Thank you Lisa Clark Lisa@Get-It-Straight.com
  • jjharv Mar 13, 2009
    I have the same problem. I cannot turn the camera on. This is such a great camera and I really need to know how to fix it. I bought a new battery and charger, thinking it was the battery, but that is not the problem.
I am having the same problem. Any suggestions???
Posted on Aug 23, 2009
    President:
  • 2,761 Answers
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Posted on Aug 16, 2009
Mine too mine is a kodak easyshare C330 and when i plug it it it won;t charge or turn on! please help im begging im taking it to camp in 2 weeks do i need a pro- help or is there an easy way (it uses AA...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success.
Jan 22, 2011 | Kodak Easyshare M753 Digital Camera
Will not start - tried new battery - didn't help
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery
c. Without the memory card, turn your camera on.
Please also try to upload new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11647/11660&product=EKN033563
KODAK is very nice if your warranty was just expred or is about to expire. I think the trick is to be as friendly as possible when speaking to the agent.
In order to organise your repair Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
I have brand new lithium batteries installed & when i turn camera on, it immediately shuts off. camera is only 1 year old
I have the same problem... cleaning the contacts does not work. I'm using NiMH 2450 mAmp batteries, brand new, and I get a low battery indicator immediately. Camera shuts off unexpectedly. A short search online indicates that HUNDREDS of people are having the same problem. Kodak help not very helpful. I'm ready to buy something else!
Dec 11, 2009 | Kodak EasyShare Z712 Digital Camera
I have a kodak easyshare v1253 and the unit turnes on, the lights activate and the lens clicks to try to open the unit turns off. The lens does not open. I sent it in for warrnety for the same problem a...
Im sorry about that, well anyway it seems that the lens of your camera is already defective,
are you using the recommended battery Lithium-Ion battery (KLIC-7004)? If yes try to charged the battery and if this issue not solve Please call kodak Toll Free 1 800 235 6325 canada and U.S support only
Nov 03, 2009 | Kodak EASYSHARE V1253 Digital Camera
Hello ive recently purchased a Kodak c913 camera and im already having problems. I am unable to get the camera to even turn on. Ive tried replacing the batteries and still nothing, it doesnt turn on whilst...
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. First try removing the batteries and cleaning the camera contacts with a small metal brush, steel wool, or fine sandpaper. If that doesn't fix the problem, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
Jul 08, 2009 | Kodak EasyShare C913 Digital Camera
Kodak easy share digital camera m863
I have a Easy Share M863 and have had it less than a year. It was working great and then last week I tried turning it on and it would not open. I thought it might be the battery needed charging so I did that. It still will not open. I contacted Kodak and they told me they would give me 15% on a new digital camera. That is not what I wanted. My camera is not even a year old. It should have lasted longer I think.
Jun 08, 2009 | Kodak EasyShare M863 Digital Camera
My kodak easy share c433
Are you using alkaline batteries? The Easy Share hates alkaline batteries. Try NiCad or Lithium.
Oct 16, 2007 | Kodak EasyShare C433 Digital Camera
Wont Turn ON!
I returned mine to Kodak (warranty) and they replaced it - was not fixable. :(
Sep 17, 2007 | Kodak EasyShare Z740 Digital Camera
Docking and charging digital camera
Not sure if this will help, but you might try removing the batteries from camera, then see if it responds on the dock, if so it is most likely bad battery. That battery should be easy enough to find at locally. You might wanna try the Interactive Troubleshooter on Kodak's site. http://www.kodak.com/global/en/service/products/ekn030483.jhtml?pq-path=6861
Jul 28, 2007 | Kodak Dock Plus Bluetooth Thermal Printer
Kodak EasyShare Z612 Digital Camera Logo
113 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
