Question about Dryers
Maytag dyrer mdg6200aww the heating systwm does not stay on
  • killdogg420 Apr 16, 2009
    Same dryer but mine has no heat at all... I think it is the ignitor but don't know where it's located... any info would be greatly appreciated.
  • Dryers Master
  • 3,361 Answers
Remove the vent from the rear of the dryer.
With no clothes in the dryer and the dryer set for hi heat run the dryer several minutes.
With a accurate thermometer check the exhaust vent temperature.
It should be 135 to 160 degrees.
If it is, you are OK. Just need to clean your vent and connecting tubing.
If not, replace your gas valve coils.
Posted on Mar 04, 2009
Where are the hold down clips on a mdg6200aww Maytag dryer?
Hi Willey:
No photo handy but,
The clips are located through the slot on the front of the unit.
They're close to the edges.
If you slide a drywall knif into the slot you will feel them. Just push them in and lift the top at the same time.
Aug 17, 2015 | Maytag Dryers
Need to relight pilot light on MDG6200AWW gas dryer.
That unit has an electronic ignitor. You should not have to lite the pilot. There is no pilot to lite. If the dryer is taking longer then normal to heat. Check your vent to the outside. If the ignitor is not turning on it could be the ignitor, flame sensor and or thermal fuse. Check D.I.Y. Appliance Repair Troubleshooting to see if there is anything that can help you there.
Mar 28, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
On my maytag model MDG6200AWW gas dryer. It doesnt heat up. I see wehre some people say the ignitor glows orange. Where is the ignitor and I don't see anything heating up. Where do I look
On your dryer to see whats going on with the igniter you need to remove the front panel and see whats happening. To remove the frony panel remove the screws on the door hinge and the screws on the other side if the door was hinged on that side and pull the front panel off. The burner asm. will be on the right side of the base frame.
Gene
Aug 17, 2011 | Maytag MDG7600AW Gas Dryer
I have a Maytag dryer MDG6200AWW and at first the machine dried the clothes fine but never shut off. The second load got hot but not long enough to dry whole load. The timer does not advance at all. ...
Remove the front panel to get to the gas valve. To remove the panel remove both screws holding the door hinges and the screws on the opposite side from the hinges across the door opening.
Remove the metal bracket holding gas valve coils.
Replace both gas valve coils, part number 279834.
Good luck,
Vlad
First Choice Appliance
Aug 21, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag mdg6200aww dryer not drying clothes
my maytag dryer turns on the gas ignites and stays on for about 1 min then the gas shuts off the ignitor glows orange every 30 sec to a minute but the gas valve does not open also the dryer knob does not go past more dry im not sure if thats also the problem
Aug 24, 2009 | Maytag MDG7600AW Gas Dryer
My maytag autodry dyer mdg6200aww begins by heating up but the gas flame goes out after a minute or two.I checked for continuity on both the thermal fuse and radiant sensor and both checked out ok.
Continuity on the radiant sensor should be "closed" at startup, but it must also open after it has sensed the heat from the ignitor or flame.
The ignitor could be cracked and opening up after it heats up for awhile, also it's connectors might be loose/oxidized, clean them and reconnect after checking the ignitor.
Last thing to check is continuity on the gas valve coils. These two frequently go bad, especially the one with two contacts rather than three.
The set of two coils is about $10,00 on ebay. buy them and install. Even if you don't need them now, you will eventually need them. They are nearly a consumable item.
Aug 02, 2009 | Maytag MDG7600AW Gas Dryer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Dryers Logo
313 people viewed this question
Top Dryers Experts
