Question about Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water
How do I replace the air filter for a 2005 sebring conv touring''
  • 408 Answers
First, this is the wrong catagory.  Secondly, take the bolts out of the air filter housing to replace it.
Posted on Mar 04, 2009
Fuel Rail Leak
Did did you change the o-ring at the fuel line to fuel rail connector? Do that before you change the fuel rail. According to an e-bay seller who is selling a used fuel rail from his salvage shop, the following fuel rails are interchangeable.
300 05-10 Fuel Injector; 2.7L and 3.5L
AVENGER 08-10 Fuel Injector; 2.7L
AVENGER 08-10 Fuel Injector; 3.5L
CARAVAN 08-10 Fuel Injector; 4.0L
CHALLENGER 09-10 Fuel Injector; 3.5L
CHARGER 06-10 Fuel Injector; 2.7L and 3.5L
JOURNEY 09-10 Fuel Injector; 2.7L
JOURNEY 09-10 Fuel Injector; 3.5L
MAGNUM 05-08 Fuel Injector; 2.7L and 3.5L
NITRO 07-11 Fuel Injector; 4.0L
PACIFICA 05-06 Fuel Injector; 3.5L
PACIFICA 07-08 Fuel Injector; 4.0L
SEBRING 04 Fuel Injector; Conv, 2.7L, from 07/30/03
SEBRING 04 Fuel Injector; Sdn, 2.7L, from 07/30/03
SEBRING 05 Fuel Injector; Conv, 2.7L
SEBRING 05 Fuel Injector; Sdn, 2.7L
SEBRING 06 Fuel Injector; (Conv, Sdn), 2.7L
SEBRING 07 Fuel Injector; (Sdn), 2.7L
SEBRING 07 Fuel Injector; (Sdn), 3.5L
SEBRING 08-10 Fuel Injector; (Conv, Sdn), 2.7L
SEBRING 08-10 Fuel Injector; (Conv, Sdn), 3.5L
STRATUS 04 Fuel Injector; Sdn, 2.7L, from 07/30/03
STRATUS 05 Fuel Injector; Sdn, 2.7L
STRATUS 06 Fuel Injector; (Sdn), 2.7L
TOWN & COUNTRY 08-10 Fuel Injector; 4.0L
Mar 04, 2014 | 2007 Chrysler Pacifica Touring
I would like to see a picture of a thermostat housing LOCATION on the engine of a 2005 Chrysler Sebring 2.7L V6. I have already replaced the upper water outlet housing, and was told it is not where the...
Click over image for zoom...
Fig. Air bleed valve (1) and thermostat housing (2) 2.7L-engine
Hope this helps (remember to rate and comment this free answer).
May 26, 2011 | 2005 Chrysler Sebring Conv
2005 chrysler sebring. when starting in am, no hot air until the car is moving...engine temp guage is in the normal range
check radiator see if water is flowing / you should be able to see water movin/ if is change rad. cap
Oct 20, 2010 | 2005 Chrysler Sebring Conv
Where is the battery on the 2005 Chrysler Sebring Touring Convertible?
Remove the drivers side front tire, in the wheel well liner there's a access plate to get to the battery.
Aug 23, 2010 | 2005 Chrysler Sebring Conv
How to change head lamp to Chrysler Sebring Convertible Touring
Remove 2 screws holding the headlamp and pull forward.
Jun 04, 2010 | 2005 Chrysler Sebring Conv
2005 chrysler sebring..car starts then dies...gas tank is almost full. help...what can this be?
Sounds like either a fuel pump problem, clogged injectors, clogged fuel filters, or a tune up issue. Start fixing the cheapest stuff first - the clogged fuel filters and injectors. Then check the tune-up specs, wires, and sparkplugs of your car to make sure everything is in order. Also, make sure your car's air filter is fine and air is getting to your engine. Finally, check the fuel pump. And dont think you always have to replace your fuel pump -- the wire to the pump may simply be loose or corroded. Good luck...
Jun 12, 2009 | 2005 Chrysler Sebring Conv
2005 Sebring 2.7L air cleaner can't get cyliner out
loosen the hose clamp at the throttle body inlet and take the intake hose off of the throttle body then the intake hose can be moved to give you the needed room and the air filter comes out with little effort
Mar 24, 2009 | 2005 Chrysler Sebring Conv
Trouble code (MIL) reset
just 10 flashes means that the OBD readiness monitors have not all been set.. when the battery was disconnected it reset the monitor status to not ready..
Jan 28, 2009 | 2005 Chrysler Sebring Conv
Jenn-Air 21.6 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Logo
205 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
