Question about Gateway M-6834 Notebook
Gateway m-6834 battery light blinking red and won't turn on
  • Anonymous Apr 26, 2009
    if the power sub system on the board is fried?...What do you do?
  • Shadow1989 May 11, 2010
    does it start with the power cord plugged in?
    Scholar:
  • 82 Answers
Either:
A) Bad battery
Easy to check, take it out and try to boot. If yes. Get a new battery.
http://www.shopbattery.net/gam6mselirel15.html
If no.
B) Bad AC adapter
Does the power brick have an LED on it? Is it on. Even if it is it may not be putting out voltage. If the cord gets bent alot it can break inside so it looks normal. If you or some you know has a MultiMeter , have them check the voltage.If you know someone with the same laptop, try theirs. If it works get a new one.
http://www.buy.com/retail/product.asp?sku=209143953&listingid=29869055&dcaid=17902
C) Broken connector inside laptop
If a known working AC adapter doesnt work there could be a broken connector inside that needs to be resoldered or the power subsystem on the board could be fried.
Posted on Mar 05, 2009
  • erastus600 Jan 01, 2011
    Mine is doing the same thing with the C) option...sorta. I removed the battery, plugged the known working AC adapter in. Power light glows blue, as it should, other parts of the keyboard light up, but the screen is blank. What's going on?
  • Billy Kidd Apr 13, 2011
    It could be a number of things but I'd start out with this sequence:
    1) Bad inductor
    2) Bad screen
    3) Defect in motherboard. (On mine there were 2 metal clips that held a cable in place. They came loose inside the machine and shorted a zener diode and inverter.
    One thing to test, plug in an external monitor, does that work? It did on mine.
My ps3 won't turn on and red light keeps blinking,
Read this:
http://www.prlog.org/10506996-ps3-red-flashing-light-causes-and-solution-revive-your-ps3-by-fixing-red-lights-blinking-yourself.html
May 15, 2012 | Sony Video Game Consoles & Games
Won't boot it only has the battery light blinking
Remove the main battery and try to power up the computer, a bad battery in some cases will prevent the laptop from restarting.
May 10, 2012 | Gateway NV53A52u
Cricket Kyocer won't turn on. Blinking red light
Try another battery. The blinking red light means its not charging and keeping power.
Aug 20, 2011 | Kyocera Zio M6000 Cricket
Why does my gateway nv53 battery light blink while charging?
Hi, The LED light on your Gateway NV53 Blinks while charging because it was designed to do so. According to the user manual, if the battery light is:
Solid Orange: Battery is fully charged Blinking Orange: Battery is charging Blinking Red: Battery is critically low Solid Red: Battery problems, contact Gateway support immediately.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | Gateway Computers & Internet
Notebook power button is blinking red when I try and turn in on. Plugged into ac adapter
sounds like bad adapter.red blinking light means dead battery.so if charger is bad it will not power the pc or charge it.
Oct 16, 2009 | Gateway M-6834 Notebook
Will not power up. trying to turn on and just the red battery light flashes
blinking red light with battery icon means that you are running out of battery power. if the computer is plugged in to the wall and it still does the same thing you may have to replace the ac adapter or charger. the charger should have a green light on it to indicate it is getting power.
Sep 29, 2009 | Gateway Computers & Internet
Doesnt stat up and no light showing charge
Here's one way to determine the problem.
Take the battery out and try to boot on AC power only, if it boots turn it back off, reinsert the battery again and try to boot.
Sometimes you just have to take the battery out and plug it back in again, with others it is the battery and you have to leave then out until a replacement is bought.
If it still won't boot on AC only, remove and reinsert the memory, try to boot the computer and listen for any beeps.
Post back if you need further assistance.
Good luck.
Aug 03, 2009 | Gateway MT6840 Notebook
Red light on the front blinks 4 times
The 4 blinks are telling you that there is a fault. The same as Computer Bios Beeps.
I,d suggest removing the RAM/Memory, and replacing it. Press and hold the power button for more than 4 seconds, to ensure it isn,t in standby mode. failing this remove the cpu and re-seat it as it may be slightly out of position, or out of it,s socket. finally have a look at the back or underside to see if there is a reset switch/hole.
Mike @ Compurepair.
Jun 12, 2009 | Gateway M-6834 Notebook
Gateway M-6834 laptop -- power blinks
Im having the same problem. did you find a solution?
May 14, 2009 | Gateway M-6834 Notebook
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
Gateway M-6834 Notebook Logo
5,562 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
