Question about HP Vectra VL400 PC Desktop
Comm 1/ no serial ports not responding.
Just installed new hard drive already loaded w/ win xp. All working except serial ports do not respond.
  • r_jmal Mar 04, 2009
    Shadow,
    The hard drive was brand new. It was pre formatted before I got it. I will check for conflicts and update. Thanks.
  • 1,602 Answers
OPEN UP THE CASE AND MAKE SURE THE CABLE WITH THE LINE ARE ON #1 ON THE MOTHERBOARD, YOU MAY OF PLUG IT IN AND MISSED THE 2ND ROW OF PINS.
GO INTO THE CONTROL PANEL OPEN DEVICE MANAGER AND GO TO PORTS
GO TO PROBLEMS REPORT, OPEN BY RIGHT CLICKING ON THE ICON, SEE IF ANY CONFLICKS.
DO YOU HAVE ANY DEVICE HOOKED UP TO IT, IF YOU DO THAN HOOK THE DEVICE UP AND GO TO CONTROL PANEL AND LOOK UP THE DEVICE AND CHECK THE DRIVERS.
LAST THING CAN CHECK GO TO START AND TYPE IN SERVICES AND ENTER KEY, LOOK AT THE COM PORT MANUAL OR AUTOMATIC.
IF THEY DO NOT SAY EITHER ONE OF THOSE
DOUBLE CLICK ON THE ONE THAT IS DISABLED WHERE IT SAY STARTUP TYPE OPTIOS ARE:
AUTOMATIC DELAYED
AUTOMATIC
MANUAL
DISABLED
THAN APPLIED, THAN OK
OTHER THAN THAT YOU MAY HAVE A BENT PIN OR SHORTED OR OPEN WIRE, BAD CONNECTOR.
RODGANDYSR
Posted on Mar 04, 2009
  • 408 Answers
Ok, if the hard drive already had Windows XP on it, it has the configuration for the computer it came out of.  you need to reinstall windows xp with the hard drive in your computer so it can properly detect all the ports that your computer has.
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
My sandisk 4gb does not respond because of com 34 problem, how do i resolve it?
doubt if you really have a com 34 maqny devices fail to read comm anything past 11. Go into windows find the device on the USB port and change the comm p[ort to one that is not in use between 1 and 11
Please rate my help++++Thanks for using FIXYA
Jun 03, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PS2 KEYBOARD & MOUSE Not responding.
Try connecting one at a time, if you connect the mouse don't connect the keyboard, and if you connect the keyboard, don't connect the mouse, reboot each time and check which one is the culprit. One of the port or device must be creating the problem. Good luck.
May 24, 2010 | Asrock CONROE1333-DVI/H INTEL 945G CHIPSET...
Cannot get my cnr modem to work with win xp
it might not be compatible with XP
check modem documents
Apr 23, 2017 | EliteGroup (CNRV12)
Five computers networked with Linksys WRT320N router. Operating systems: Win 7.0 on 3 computers (two hardwired)(one laptop - wireless), Snow Leopard 10.8 on 1 (wireless), and XP on one (wireless). Also...
Sometimes this problem occures when you install a later model wireless router.
Try installing the latest Wireless card driver on the XP computer and the LAN card drivers on the other computers except the MAC.
Dec 31, 2009 | HP LaserJet P2015n Printer
Installation for xp problem
all the hardware on the laptop is most likely configured for windows vista meaning it will not allow xp to load up because your hardware cant run it
Oct 09, 2009 | Compaq Presario Notebook
I/O SERIAL PORTS NOT RESPONDING.
reinstall the chipset driver of off the motherboard cd.
This should also help with any other on board devices.
Ian
Mar 04, 2009 | HP Vectra VL400 PC Desktop
Windows XP stopped recongizing eGo external Hard Drive I just installed a new iomega eGo 1 TB desktop Hard Drive yesterday, got the bugs worked out and my Dell w Windows Xp seemed to recognize it, Today,...
2 things... the USB port is bad, or the USB cable is too long and the HDD isn't getting a good signal.
1. Try another port and see if that works
2. Nip over to WalMart, Circuit City, Micro Center, PC World or Best Buy and get a shorter, Thicker USB cable of the same type - a cable which can provide the signal strength your ext HDD requires.
Also a possibility... The HDD may be 'lost' as Win cannot accept one of that size or the label/signature fell off and it is an orphan. It MUST have a driveletter, and it MUST have a special WIN signature byte on the HDD for it to work.
Bootup as normal, let everything get quiet, then plug in the ext HDD
Rt Click My Computer, Manage, Device Manager and in the Rt side, highlight the TOP icon. Then under Help, click the Computer with magnifying glass icon and wait. This forces your OS to 'Look' for any new devices.
When it finishes looking, look again under My Computer to see if your new HDD is now there. It will have to be formatted and have a driveletter for this part to work. Jump down to Disk Manager and see if it is there. You may have to Rt. Click and import it as a foreign drive or Rt click and give it a Driveletter ;-) If it is not, use a shorter, thicker (more wires) USB cable and try again.
Windows doesn't like Any HDD without win signatures on them - aka:'foreign disks' so ANY time this happens, if OS doesn't see it, use disk manager and Import it, then Rt click it and give it a Diskletter.
Jan 15, 2009 | Computers & Internet
Hard disk is not responding while installing os
1st plug any hard disk of urs and get a bootebel cd u can say not the xp 1 but u can find old cds like windows 98 or milenium and boot it..after sellect the cd rom support aplication..wen loaded right fdisk select yes and yes..after that delet dos or any existing partitions and restart do the sam thing again but this tim make dos partition wen ur finish restart and go in again but wen loaded on a:\ wright format C: and accept..after format is finished retstart but this time boot frome windows xp or the operation system disk u want 2 install..and folow the instruction..and if i didnt work after u do all that u go 2 ms dos and make a scandisk for c after u format u can see all comands in a:\dir , thats all and 4 the other hard drive u dont need 2 do the same just after u install widows u plug it and go 2 cotrol panell in administrative tools and select the icon that have a pc signe and after that frome the second option u select the 3 and u see ur second hard disk format it and scan it and evry thing will be just fine........
Feb 04, 2008 | Seagate (AU-80GBSATAHD) 160 GB SATA Hard...
HP Vectra VL400 PC Desktop Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
