Question about Refrigerators
Does anyone know how to connect a refrigerator to a water supply?
There is no water tap in my kitchen behind where the refrigerator goes. Is there an easy/standard way to install one?
  • 59 Answers
You don't want the tap behind the unit. Either run the water line behind the cabinets, through the basement or crawl space from the nearest sink or water line and put the shut off where the new line meets the existing line.
You should be good with 1/4" line, I would advise against using a self piercing valve, they are easy but can lead to leaks and more issues.
Posted on Mar 04, 2009
Tip
How to repair an ice-maker of a refrigerator
An icemaker receives water through a small, 1/4-inch water supply line that runs from the refrigerator to a water pipe, where it is connected by a tap valve. The water supply line enters a valve in the refrigerator that is controlled by an electric solenoid that sends water through a fill tube into a mechanized icemaker assembly. There, the water freezes and is dumped into an ice bin. When the bin is full, the ice lifts a bail wire that turns off the icemaker. If the water’s route is blocked or the solenoid doesn’t work—or if the bail wire is lifted—the icemaker won’t make ice. (Also note that your home’s water pressure must be strong enough to serve an icemaker.)
Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
1) If the icemaker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
2) Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
4) Check the tap valve; a bad tap valve may cause the problem where the icemaker’s supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
5) The water line attaches to a solenoid at the back of the refrigerator and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first. Unless you’re skilled at home repairs, this job is better left in the hands of an appliance repairperson.
on Sep 02, 2010 | Refrigerators
Ice Maker not receiving water past the valve? at the bottom of refrigerator.
tap gently on solenoid . it is probably stuck from corrosion. if that doesnt work you will need a new one. go to any appliance parts dealer they should be able to supply you with a aftermarket replacement water valve.
May 26, 2012 | Roper Refrigerators
DRIPPING WATER DISPENSER FLOODING DRIP TRAY AND POURING DOWN TO FLOOR
Water solenoid inlet valve is getting stuck slightly open, It's located behind the refrigerator on the bottom where main supply hose connects. You can first try tapping it and see if that helps otherwise it would need to be replaced.
May 14, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My refrigerator shows an ice make but i can not find the connections to it
THE CONNECTIONS ARE BEHIND THE UNIT TURN IT AROUND AND YOU CAN SEE THE WATER HOSE CONNECTORS, YOU HAVE TO DO SOME WATER INSTALATION FROM AWATER SUPPLY THE MOST COMMON IS THE ONE BY THE KITCHEN/SINK. WHAT YOU NEED IS: A SET OF A COPER TUBE INCLUDE ONE SMALL REFRIDG WATER VALVE. MAKE SURE YOU LET ALL THE AIR OUT FROM THE WATER LINE BY KEEP THE WATER RUN THROUGH THE LINE FOR ABOUT 1 OR 2 MUNITS. AND PUTT EVERYTHING BACK TOGETHER
Oct 24, 2010 | LG LFC21760 Bottom Freezer French Door...
We have a kitchen aid refrigerator and we hooked up the copper water line. The water comes thru the door but it is not making any ice. We need to know if there is something more we need to do so that the...
First the white plastic tubing is the supply line inlet for the water to the ice maker. It should be connected to a water supply somewhere in the kitchen. This line goes inside the refrigerator to some relays that turn the water on and off to the ice maker. You will have to check these relays for proper function and depending on the year of your refrigerator will depend on where these are located but most of the time at or near the bottom in the back.
Also there should be a large filter on the back of the frig. check to see if that is clogged. This is the easiest to do first.
Sep 23, 2010 | Refrigerators
Plum in a Amana fridge freezer
hello. I am assumming that your model has the ice and water dispenser. Not all models do. On the rear of these models with the ice and water feature you will find a small [1/4 inch] line that has to be connected to a cold water supply source. If you go to most any hardware store you can get the little kit necessary to make this connection. The kit consists of a length of 1/4 inch tubing, the connector to attach to the tube at the rear of your appliance, a valve and a tapping kit to tap into your closest cold water source. If the fridge is near the kitchen sink, you may choose to connect under the sink. If not, make sure you purchase a kit with enough 1/4 inch tubing to reach your nearest cold water pipe. J.
Jul 20, 2010 | Amana 22.6 cu. ft. Side-By-Side...
WATER DESPENSER RUNS AUTOMATICALLY EVEN WITH LOCK ON AND IS FLOODING MY KITCHEN HELP
If it's running continuously then your water inlet valve on the back where the water supply is connected is probably stuck partially open. You can turn the water off under the sink or with the saddle valve behind the fridge.
Apr 20, 2010 | Kenmore Refrigerators
Water from the kitchen tap is good tasting, water
The water has been in the tank for too long. Draw and discard a least 7 glasses of water to freshen the supply. Draw another 7 glasses of water or more to completely rinse out tank. Repeat the process if necessary.
Oct 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
HOOK UP OF ICE MAKER TO THE WATER LINE
What you have in the back is a 1/4 tube which will feed cold water to the icemaker.
go to any hardware store and ask for an icemaker supply line kit. It will consist of a tapping valve, about ten feet of 1/4 inch tubing and a straight connector.
it will also contain step by step instructions.
You will have to determine what cold water line to tap into that is accessable. Perhaps the kitchen sink cold water supply if it is on the same wall as the refrigerator. Many times the line is run up from the basement.
enjoy your new icemaker.
May 21, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
266 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
