Question about Dictaphone 3225 Handheld Cassette Voice Recorder
When boss dictates a letter I can barely hear any sound!
I changed the batteries and it still sounds like someone far off talking
  • kshaleus Mar 04, 2009
    we use about six different tapes a day so it's not that and it's a fairly new recorder (one year). Thanks for the help though
    Problem Solver:
  • 3 Answers
I have worked on these units for years, & it sounds like the Head alignment is off or possibly a dirty Record/Play Head. If the unit is a year old & has not been regularly serviced by chance. Are all tapes like this or only from one specific recorder? Try Cleaning the R/P Head in both of the units & if this is still not satisfactory, have some one give you a good tape recorded on a known good unit that you can hear OK. Next, with a small blade "Jewelers Screwdriver" (very small tip Phillips blade) in the very small hole above the head, turn the screwdriver carefully & slowly CLOCKWISE while playing back a known good tape in the unit in question, recorded on a different unit. If all tapes sound this way on the transcriber, use this procerdure on this machine. If not, use it on the one that the "Low Volume Tapes" are coming from only. To confirm this, if the "loud & Clear" sounding tape from another recorder is played in the unit in question, & all other tapes from every other unit sound OK, the one that plays them very low is the correct unit to adjust. Good luck!
Posted on Jun 14, 2009
  • 43 Answers
You could try setting the mic sensitivity to 'Conf'. This will make it more sensitive, which will make his voice louder - but may also pick up more background noise.
Also, I think those portables have the ability to record & play in two different speeds. Make sure he's recording in 2.4 speed. He'll get half the recording time per tape, but the recording quality will be much better.
Posted on Mar 13, 2009
  • 408 Answers
The tape might be getting old, replace it and see what happens.  If it is still acting up, It might be he is not recording properly or the recorder is bad.  Try talking directly into the mic and see if it is better.  If it is, he needs to talk louder or needs to hold it close.
Posted on Mar 04, 2009
BPR40 Receiving a static reception when someone is talking
Several things need to be checked. Fully charged battery. Antenna, make certain it s tight and unbroken. Wiggle the antenna while receiving, if reception improves, it is the antenna or the antenna jack. Then wiggle the on/off vol switch, same thing, if reception improves, it is broken or needs to be resoldered. Then I check the speaker. Speakers gather metal particles, as they get more and more, the speaker distorts and it sounds like static. Use a powerful magnet, run it over the speaker grill and see if anything comes out. I put plastic wrap on the magnet for easy cleaning. It could still be a bad speaker. Last, I check programming. All of this is done at our shop regularly and I suspect most radio shops follow the same procedures, maybe in a different order. Post if this helps or not.
May 17, 2016 | Motorola MagOne BPR40 UHF 8-channel...
Callers cannot hear me reply,I can hear them ?
Sounds like you have your phone on MUTE. If so the word MUTE should be on your screen. It might be in the upper or lower corners of your screen.
To unmute.....while in the TALK the soft key on the far right of the menu key. it should look like this -> -> . MUTE should then clear off screen. You can now hang up. Now go back to TALK and call someone and see if that corrects your problem. Happy talking!
Sep 17, 2011 | Philips CD235 Twin Cordless Phone
Cb puts out good sound but when someone try to talk to me it all you hear is static
same thing sometimes happens to me. Usually it is because the person who is talking to you might have a weaker antenna. Sometimes people put a very strong transmitter with them and talk to people but you cant talk back.
So really they can't hear you good either. Just because you are too far away.
Jan 11, 2011 | Cobra 29 LTD CB Radio
I hear my voice echo some of the time (no particular relation to location) when I talk to someone. Why and how do I get it fixed? Thanks
This has no problem to do with the phone as far as i know.
It occurs normally when you are talking to someone who happens to be in a very quite and large room without that it empty. this is due to the empty vaccumm that causes the sound that is produced to be reflected back into themic of the phone and as a result causes you to hear your voice.
Also, another thing that causes it is when you talk to someone who puts the call on loudspeaker and there are multiple surfaces causing the reflection of the sounds you make.
In summary, there is nothing wrong with your phone and you just need to tell whoever you are talking to to try and move to an area that is a bit occupied so as to prevent echoes.
Dec 24, 2010 | Samsung Convoy Cell Phone
The sound is suddenly very quiet.
this phone has many different volumes to play with, one of them is the volume for, when your calling someone, simply, when you call someone, press the volume up button, and you should hear the person louder
Oct 21, 2009 | Samsung Propel A767 Cell Phone
Just hooked up Coax cable; now talking is barely audible
is the center speaker turned up in the reciever speaker settings? each speaker can be adjusted to a level that is higher or lower or all the same as the rest. also is the dolby digital turned on in the reciever settings? and changing the surround sound pre set sounds can also improve the type of audio you are listening to in 6.1 surround sound
Dec 31, 2008 | Sony STR-DE597 Receiver
Chocolate mic
Your probably going to have to take it in to your Cell phone service provider. I had the same issue and it ended up getting worse(meaning no one could hear me) and i had to have the phone replaced. More than likely something came loose.
Jul 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Skipping of Sound Files
format card through the recorder should clear up most of the problem after you have downloaded the files
Mar 28, 2008 | Olympus DS-2300 Digital Voice Recorder
People can not hear me
Taking into a repair center you have a bad microphone
Jan 03, 2018 | Samsung SGH-x426
Dictaphone 3225 Handheld Cassette Voice Recorder Logo
253 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
Alan W Kelly
Alan W Kelly
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
