Question about Eiki LC-XG210 Projector Multimedia Projector
3-way wall switch left in up/down position
I have 3-way wall switches to lower and raise both the screen and projector from the ceiling. Is it necessary to return the switch to the neutral position, or can it be left in the up/down position without burning up the motor?
    Scholar:
  • 93 Answers
Most Projection screens which are electronically operated have a couple of switches inside, so that when the motor runs to the stop point, the switch activates and the motor stoops. The central point is there purely to allow you to have the screen at a custom height, say to make a 4:3 screen appear as 16:9 without loads of white space around the picture. Also, if the motor didn't stop, it wouldn't burn out at low point, as it would simply wind the screen back up the wrong way round the axle.
Hope that helps.
Jay
Posted on Mar 04, 2009
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
Upside down picture how do you invert the images projected
Go to menu and select images and click arrow left or right to invert image position.
Mar 21, 2010 | Eiki LC-XB20 Projector Multimedia...
Casting image lower on wall
I don't know the model number for your projector, but most projectors are designed to place the image level with the bottom of the projector, which works great for tabletop mounting but not so great for ceiling mounts.
If you're mounted at ceiling height, try turning the projector upside down to see if it places the image in the right place on your screen. If that fixes it, then use the on-screen menus for your projector to flip the image and you should be all set.
Dec 09, 2009 | Dell Office Equipment & Supplies
Infocus X10 projector overheating.
okay most people think well its not hot up there but truely it is hot toward the cealing. If its overheating on the roof mount try to use a wall mount instead.. If they have it running for 5 days streight then is something your not oding right here and that might be the mount.
Nov 10, 2009 | Sharp XG-PH50X Multimedia Projector
Eiki EIP-25 shuts down after 30 sec (ceiling mounted)
there must be something loose inside. maybe the button panel.
Mar 07, 2009 | Eiki LC-X50M Projector
Ceiling installation of pull down screen
Found the correct clips (at an acustical supply store) needed to install the 120" Projector Screen to the 'drop' ceiling in our office. Thanks anyway.
Jan 26, 2009 | Focupix 4:3 Standard Format Manual Pull...
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Ghosting
Get firmware upgraded.
Oct 30, 2007 | NEC VT465 Multimedia Projector
Eiki LC-XG210 Projector Multimedia Projector Logo
338 people viewed this question
Top Eiki Office Equipment & Supplies Experts
jasbo
jasbo
neOen
Level 1 Expert
Jaime Hernandez
Are you an Eiki Office Equipment and Supply Expert? Answer questions, earn points and help others
