Question about Frigidaire FRS23H5ASB Gallery 22.6 Cubic Side by Side Refrigerator
Frigidaire FRS23H5ASB is too cold
I opened my refrigerator yesterday, and noticed that the water bottles and several other liquid containers had froze. I turned the setting down to the factory setting (3) and then checked it again today after about 24 hours. Now even more things are frozen, and it is not getting any warmer. I put a thermometer inside and it currently reads at 31 degrees F. Cold air is still blowing in from the vent. I notice no change to the freezer side.
The model is a Frigidaire FRS23H5ASB. It is 5 years old.
What could the problem be?
  • 400 Answers
Your thermostat is faulty and needs replacing
Posted on Mar 05, 2009
Loud noise in freezer. Removed inside panel and ice build up from water line was pushing fan and hitting connector. How do I remove back panel?
You have to find out why the defrost timer did not turn on the mullion strip heaters first. Simply turning the thermostat off for a few hours will melt the ice build up without having to disassemble the refrigerator. Water may leak out on the floor from the ice build up but it will stop soon enough. Back to the defrost timer. It sounds like it is not working or if it is then there are some open heat elements where the ice has built up. The timer is usually located behind the toe grille at the bottom of the frige. Your location may be different, so go online with your model number and look up the exact location.
Sep 24, 2014 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Compressor wont come on
sounds like it froze up, is the fan in the freezer running? remove everything from the freezer and let it thaw out wait till its warm to the touch, and check the water pan underneath might run over then plug it up again and watch the fan, it must run or it will freeze up again might need oil or just turn it a few times to get it going
Jan 27, 2014 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Where is the defrost timer
If your unit is an auto-defrost unit, doubt you will find one on the appliance.
Aug 08, 2012 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
I don't know what happened to my refrigerator but it is starting to freeze everything. I couldn't change filter because it was stuck, frozen in place. So i had to turn the fridge off so it could thaw out...
1 setting on a fridge is as cold as it can get so it will be close to freezing
should be set on 4 or 5
next if it still is freezing then the thermostat is failed and you will need to replace it
May 09, 2017 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Both the freezer and lower section of refrigerator does not get very cold even at the highest settings. The motor seems to be running all the time and is noisy. Yesterday though I noticed it not running...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 31, 2010 | Frigidaire Refrigerators
There is a part of my car that looks like a container attached with the radiator- it reads danger, do not open (Carlsonic). it used to have a green liquid in it but the liquid has finished in the...
This is the overflow bottle for the cooling system in the cars motor.On the sides will be lines that read (maybe) hot and cold.You will need to add some water to this bottle so the radiator has water in it.The green liquid is the engine coolant.If you drink it.You die.Its name,if you buy some is called,engine coolant.Hope this helps
Mar 23, 2010 | 1999 Mazda 626
The freezer is not getting very cold - ice forms but ice cream stays very soft
check the temprature and turn it off for some time and read menual for temp.
Jul 25, 2009 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Water dispencer drips into overflow tray
Needs a replacement kit. Not too hard to do yourself.
Jun 27, 2009 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Frigidaire FRS23H5ASB Gallery 22.6 Cubic Side by Side Refrigerator Logo
212 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
