Question about Jensen 8.5" Overhead DVD Player Package (MVB85) Car Monitor
Jensen JN-102 DVD mechanism mechanical part diagram needed
I have a (Jensen JN-102 overhead DVD System). I am looking for the DVD Mechanism parts exploded view diagram and parts list. I need to find the part number for two parts in the top load section of the DVD Mech. I know what the parts are that are broken...I need the manual or diagram to locate the specific part or reference number.
Any info will be helpful.
  • 1294 Answers
SOURCE: need manual for jensen cd4610
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 01, 2007
SOURCE: a broken screen
I just pulled a nearly new one out of our Expedition prior to trading it in. I have the unit only with remote. No mounting braket and I kept the headphones for our new vehicle. Will consider all reasonable offers.
Posted on Sep 22, 2008
SOURCE: Please help.... I need a wiring diagram or pinout for my Jensen xa1120 amp, thanks
xa 1120 amp pin out 123
456
1 left neg
2 ground to radio
3 left positive
4 right neg
5 blank-not used
6 right positive
Posted on Oct 10, 2008
  • 20 Answers
SOURCE: Jensen XA2150 Hi Input help
According to crutchfield, this connector should have come with the amp. Was this an open box? I would suggest getting a replacement molex connector from jensen. I see what you are talking about in the manual, and if you don't have the supplied connector, you have a big chance of frying your amp. The manual expects you to have this connector, and is not specific about the actual pins. For all you know, you could be wiring it the opposite way. Either that of call jensen, and ask how the pins are layed out. If you are confident you do have it wired properly, you could try both pins, and see which is the ground, but this is risky of course. There is also the chance there is no actual metal connector in one hole. You can also test for impedance if you have a multimeter, and you definitely should if you are taking shot in the dark with your amp.
Posted on Nov 19, 2008
SOURCE: need list of radio stations for my Jensen MVB85 DVD player
88.3
88.7
89.1
89.5
89.9
Posted on Jan 16, 2009
Why does the dvp-ns905v keep switching itself off when power is turned on?
Something may be jammed in the mechanism or the mechanism may have a bad part causing it to be out of alignment--that is first thing to look for--also the unit may just have a bad power supply but look to mechanism first.
Apr 09, 2012 | Sony DVP-NS905V DVD Player
DVD player not working.
Hello
The changer mechanism should be suspected. It is a skilled work to look into. You have to disassemble it. There are three microswitches inside the mechanism, which give signals of the state of the mechanism to main system control IC. If the loading gear wheels have some problem, these witches won't engage well, and the the whole mechanism will be inoperative.
Mar 04, 2012 | Panasonic Televison & Video
Hp laserjet 4250dtn tray 2 & 3 will not lift
Any message appearing? like 60.X ? '*Open 'tray two' check 'open message (if No check switch 102) YES '*remove tray2 lift drive mechanism(RM1-1074-000CN) check is it working? YES '* check tray mechanism is it engaging to the lift mechanism? '* check connector/cable of lift drive motor* if not working replace lift drive mechanism '* mechanism is good replace DC controller.
RM-1074-000cn
Sep 06, 2011 | HP 4250dtn Monochrome LaserJet Printer
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
The CD loading mechanism wont take in cd's
Please check the gears of mechanism motor for defective and replace it accordingly
Jan 28, 2011 | Audiovox Jensen VM9324 2 DIN 6.2"...
My dvd player wont accept discs
It is possible your dvd mechanism or drive has failed. please remove the player carefully , open the top and check from the point of transit to the slot for the head spindle. check for any dirt/dust/ particles stuck around to prevent smooth transport. look for the loading motor mechanism, drive for friction. correct settings. However is all the mechanism seems in order, then you will have to check on the motor drive, check for signals fromt the processsor to confirm failure of the drive- see if +B is coming to the drive. If not replace. Once the cd goes in , it should land on the spindle and start reading. Helpful.? Good day
Jul 12, 2010 | Jensen VM9410 Car DVD Player
DVD tray is stuck
If your DVD tray is stuck, that simply means there is a problem with the mechanism that is controlling the tray from the inside part of the player.
For you to fix this, get the appropriate screwdriver,
open the back cover of the player.
you will see a mechanism by the side of the opening and closing of the tray.
Carefully examine the mechanism, and you will detect what is faulty on the mechanism.
You can replace the faulty mechanism or better still replace the whole mechanism.
Ensure the disc tray is properly seated.
yest it with a DVD disc before you couple it back together.
Take care
Jun 18, 2010 | Televison & Video
Keeps ejecting and wont take a dvd
Hello, The problem could be the mechanism, or some part of the mechanism that is the rubber attached to the motor of the mechanism . This you have to do by removing the cover the dvd player and it involve some technical skill . if cant operte then contact the manufactuer..
May 16, 2010 | Sony DAV-SC8 System
I inserted a CD in the disc tray, it isn't playing and I cannot get the door to open, either via the front panel or the remote. Help!!!!! how do I open it? Thanks Oops, this is a Jensen JHT350 Home Theater...
U have a mechanism problem inside. Theres a problem with the gears or its out of alignment or the belt has worn out which ejects and inserts. Seek your nearest tech center.
Jan 16, 2010 | Jensen Televison & Video
Can you help? Stereo does not take in any discs
I think you have a mechanical problem with the load and eject mechanism. Either a spring or a gear has popped out of place or may be a switch got stuck and malfunction. If you are mechanical incline just open the unit up and look for anything that look out of place, becareful and remember what goes where so you can put it back in order. That is how I fix mechanical problem. Good luck.
Apr 01, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Jensen 8.5" Overhead DVD Player Package (MVB85) Car Monitor Logo
409 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
