Question about HP Compaq Presario V5000Z Notebook
Compaq presario v5000 won't start or post
My compaq starts, the fans work, then it quits with the power button blinking. I replaced, hd, power adapter, and battery, but still powers on a few seconds and quits with power button blinking.
    President:
  • 2,653 Answers
It's the motherboard. Check to see if yours is still under warranty even if you've had it for over a year.
HP / Compaq has recently extended their warranty period for certain models.
Warranty Check
Let me know if you have any other questions.
Posted on Mar 04, 2009
Compaq presario cq62 won't start but the caps lock led blinks continuously and the wifi led remains on continuously, tried new cpu, worked for a while and started same problem again.
those are blink codes, learn to count them.
if you pulled the CPU i bet you that you used the wrong heat sink compound.
The CPU shuts off all by itself if too hot. your job is to get the fan working and the heat sink working and that thermal compound right.
hp.com
as the blink codes we are not HP here, ever
https://support.hp.com/us-en/document/c02222922
Jun 01, 2017 | Compaq Presario CQ62-209WM
Compaq presario won't boot caps lock blinking power button on
hi
maybe you have change the keyboard , it is failure
Sep 05, 2012 | Compaq Presario Notebook
I have a compaq presario v5000 but the wireless switch cannot be turn on
At the top of your key board right below the power button, there is a row of hotkeys the far left one is the wireless button.
Also
have you gone into your device manager and seen if the wireless network device is turned on/enabled?
Nov 15, 2010 | Compaq Armada M700 Notebook
Compaq presario v5000 won't stay
sounds like overheating , probably due to the cpu or gpu fan/heatsing loosing contact, even a little knock could have caused this
Jul 16, 2010 | Compaq Presario Notebook
Presario V5000 - Thee machine was borrowed out
look it may be a static charge on the motherboard but there are alot of things that make this kind of problems to cut them out try to plug the notbook on external monitor and if it worked you will have a problem with your screen if not then there is a problem in the motherboard
Nov 08, 2009 | HP Compaq Presario V5000Z Notebook
My compaq presario v5000 a 5240NR was working fine
Fn+F1 Decreases the display brightness. Fn+F2 Increases the display brightness
Oct 01, 2009 | HP Compaq Presario V5000T Notebook
Your laptop runs on 18.5 volts DC at 3.5 amps.....Check the output on the printer power pack, if it is not the same, you have probably cooked your motherboard and that is what you will need to replace. Laptops do not under any circumstances like power that is not speced to thier configuration.
Sep 29, 2009 | HP Compaq Presario V5000Z Notebook
My compaq presario v5000 does not power on?
Please try to plug the power cord into the source and used DC power source. Let the laptop charge for 5 - 10 minutes then after the given time please turn on the laptop. If it does not work extend the time from5 -10 to 15 - 30 minutes then repeat the stpes again. If it does not turn on then please try to check if the battery is charging. Then if all the procedure you have already perform and still no positive result then i advice you to please find a computer technician in your please and let that person fix the problem for you.
Thanks
Aug 04, 2009 | Toshiba Satellite M40-S417TD Notebook
HP Compaq Presario V5000Z Notebook Logo
494 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
