Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
Oven will not heat
When I turn on the oven it will not heat to 350 in the BAKE MODE but works perfectly fine in BROIL MODE.
  • Anonymous Mar 26, 2009
    I can pre heat to 350 but it will not bake right, It win't turn brown nor get done in the center
  • 408 Answers
Sounds to me like your bottome element is burned out.  I would replace this, or at least take it out and bring it to an appliance store to have it tested.
Posted on Mar 04, 2009
JKP86-27 neither heating element (broil or bake) is working. Other controls and microwave work fine.
having the same problem, microwave works however oven does not heat up. The controls work, I can set the temp and bake, the fan turns on but the oven does not heat.
Nov 25, 2010 | GE JKP86 Electric Double Oven
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
My oven broiler does not seem to be working-I turned it on broil for about 15 minutes - no heat, nothing. On normal bake, it takes about a half hour to heat the oven to 350 degrees - my old stove took...
check the bake (lower) element, mine just went out. It was easy to spot the problem once I pulled the element out, the wire had burnt off the end. Please remember to turn the power off first.
Nov 28, 2009 | Whirlpool RBS275PD Electric Single Oven
Oven stays in warm up mode
does broil work? if broil works and bake does not you have a bad bake element. let me know how it goes
Jun 14, 2009 | Frigidaire Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Stuck in broil mode
sounds like you need to call MAYTAG repair service ,control board has probably failed .we do not recommend DIY fixing of any gas appliance.
Feb 15, 2018 | Ovens
Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
Dec 11, 2007 | Amana AOCS3040 Electric Single Oven
No heat
relay in the control circuit maybe bad
Aug 23, 2007 | Bosch HBL 5056 Electric Double Oven
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Electric Oven Won't Heat
Rob, sounds like it was just installed. You need 240V on this unit. On the terminal block in back where the power hooks up, it should read 240V across the two outer terminals and 120V from each end to center terminal. Im ruling out the thermal cut out because you never used it. I would start with the power source first. The display sounds like it's getting the 120V it needs to funtion, but I don't think your making the loop for the 240V needed for the bake and broil. Catriver.
Jul 12, 2007 | Whirlpool RBS275PD Electric Single Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
236 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
