Question about Epson Stylus CX3200 All-In-One InkJet Printer
My epson stylus cx3200 is not printing in black but does print colour even though ink levels in both colour and black cartridges are fine
  • rjakeespera May 19, 2009
    how to put the ink inside the printer
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Try printing a test page. Does it print in black? If not then the most likely cause is a clogged nozzle. If a couple regular nozzle cleaning cycles does not clear it up then it would need to either be sent or taken to an epson authorized repair center for service as this is not a user servicable part. Hope this helps.
If you are brave I had the same problem. I removed my ink disconnected the data ribbon to the Head. Took off the nozzles. I used a child's med. syringe with the tube. Filled it will rubbing alcohol. placed the tube on the head where the ink cartage attaches and slowly put pressure on the syringe. Be care full it will flush the black ink everywhere. I kept doing this till the black was all flushed out. Put it back together. make sure you put the ribbons back in the right way. Mine works great.
Posted on Mar 10, 2009
CX 3200 Epson, prints colour fine but does not print black, just had my cartridge refilled but still no print in black.
Hi!
Run a Head Cleaning Cycle. If that won't help. chances are the tubes are already blocked with the ink from previous cartridge. You can bring it to a Certified service center but its better getting a new one.
Hope this helps.
May 05, 2011 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200 wrong colour
It is possible that when the printer senses not enough black ink it will swap to using the colour tanks to try and make a BLACK.
It is also possible that you have mistakenly adjusted a setting in the epson printer program to use the colour tanks to print black and white photographs.
Either of those would certainly cause the problem you describe
Check ALL your printer settings both the windows ones AND your epson ones
If you found this information useful pleas click below
Aug 12, 2009 | Epson Office Equipment & Supplies
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My epson stylus cx3200 is not printing quality images
clean heads and nozzle (a few times) in maintaince. Check allighnment there too and chose correct paper setting for the paper you use
Feb 18, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Spaces and gaps in black printing
I cleaned the ink heads and it fixed the problem.
Jan 07, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Possible to print only black when colour cartridges are empty?
This printer does not let you print if even one of the cartidges is out of ink. I suggest you replace them and then in the printer properties change your settings to the way you want color to be spent.
Aug 04, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Printer refuses to print black
Hi, I have question?
The ink that yuo are change are original epson cartidge ink?If yes , try to head cleaning twice and then nozzle check ,then the result of test print are soild in color are good , the unclean head having plenty spaces within the color in test print.
Jan 07, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Blank pages
Even though I changed my black and colored ink cartridges twice, the printer still prints blank pages. What should I do?
Dec 21, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Colour printing
Check the following thread, it might apply to your problem. and just as a printer can be fooled to show a low level ink, I guess it can happen the other way around. http://www.fixya.com/problems-solutions/t103191,p342983/Epson-Stylus-Photo-R300-InkJet-Printer.aspx Good luck
May 19, 2006 | Epson Stylus C64 InkJet Printer
Epson Stylus CX3200 All-In-One InkJet Printer Logo
644 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
