Question about Canon PIXMA MP160 All-In-One InkJet Printer
Scan to pc
How do i scan a document and send to pc so as to E-Mail it.
When i press the scan button it scans and prints strait away.
  • 214 Answers
There's several ways to do this. I will tell you the easiest, (at least to explain).
1st- scan the document as usual, save it to your documents. ( to do this, look on your desktop for Canon Solutions- if not there it will be in your programs. This will open a box letting you scan from your scanner & save to your PC)
2nd- open an email, address it. Then click on the little icon at the top of your email that looks like a paper clip. This will open a box, just navigate to your documents & click once on the document that you want. This will put it in the email & you're ready to send. If you don't see a paper clip icon then click on 'insert'. This will do the same thing. If this helps plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
Posted on Mar 04, 2009
I want to scan a document to send to email how do I do this
scan the document , save to your pc , laptop , then when wanting to send on attach it and send
Mar 15, 2016 | Canon PIXMA MX432 Office All-In-One Inkjet...
I have a lexmark 464de mfp. How do i setup scan to e-mail on windows 7 on this network printer?
Multi-function printers cannot scan and then e-mail the scanned image. They can scan and then fax a document.
You need to scan the document, then save the scanned image, open your e-mail program and create the e-mail then attach the image file (file attachment) to the e-mail before you send the e-mail.
Jul 08, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Need instructions on how to send fax, it seem as though we are not following the correct steps
Solution: Sending faxes on an MX310
Sending Faxes
The operation flow of sending faxes is as follows.
  1. Load the original on the platen glass or on the Automatic Document Feeder (ADF).
    Platen Glass
    1. Lift the document cover (1).
    2. Place the original in landscape orientation and align the upper corner of it with the alignment mark (2) as shown in the figure below.
    3. Gently close the document cover.
ADF
  1. Remove any documents from the Platen Glass.
  2. Open the Document Tray.
  3. Load the document in the ADF.
    Load the document with the side you want to copy, scan, or fax facing up in the ADF.
  4. Adjust the Document Guides to match the document width.
  1. Press the button.
  2. Adjust fax settings as necessary.
  3. Start faxing.
    1. Dial the recipient's number using the numeric buttons or coded speed dialing.
    2. Press the button for color sending, or the button for black & white sending.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
    3. If the document was loaded on the Platen Glass, the following message will appear. Load the next page on the Platen Glass.
    4. If you have only one page of document to scan, go to step 5.
    5. Press the same button as you pressed in step 4b.
    6. Repeat steps 4c through 4e until all pages of the document have been scanned in and then go to step 5.
  4. Press the button.
  5. To cancel sending a fax, press the button. To cancel sending a fax while it is being sent, press the button, then follow the instructions on the LCD.
Adjusting the Scan Contrast or the Image Quality (Fax Resolution)
Contrast is the degree of difference between light and dark. Increasing the scan contrast setting further blackens dark areas and whitens bright areas, whereas decreasing the contrast setting reduces the difference between bright and dark areas. You can adjust the contrast among three contrast levels.
  2. Press the button.
  3. Press the (left) or (right) button to select the contrast.
  4. Pressing the l_mark.jpg (left) button decreases the contrast, and pressing the r_mark.jpg (right) button increases the contrast.
  5. Press the button.
Adjusting the Image Quality (Fax Resolution)
You can adjust the image quality (fax resolution) of the document you send. The higher you set the image quality setting, the better the output quality will be at the other end, but the longer it will take for the transmission. Adjust the image quality according to the type of document you are sending.
  2. Press the button two times.
  3. Press the l_mark.jpg (left) or r_mark.jpg (right) button to select the resolution.
STANDARD:
Suitable for text-only documents.
FINE:
Suitable for fine-print documents.
PHOTO:
Suitable for photographs.
Return to Start Faxing
Back to the Top of the document
Dialing the Coded Speed Dial
  2. Press the numeric buttons to enter the two-digit code (00 - 19) assigned to the number you want to dial.
  3. Press the button for color sending, or the button for black & white sending.
    Note:
    * To cancel sending a fax, press the Stop/Reset button. To cancel sending a fax while it is being sent, press the Stop/Reset button, then follow the instructions on the LCD.
Feb 04, 2011 | Canon PIXMA MX310 All-In-One Printer
How to scan a document and email it
you need to install hp 5610 driver from your cd in your pc
and then just scan it by pressing scan button ,save it as jpg and then send it by mail
Oct 05, 2010 | HP Officejet 5610 All-In-One InkJet...
I am trying to figure out how to use my Brother MFC-8440 scanner. I would like to use it to scan documents to email out. When I go to Brother.com and look at the direction book, it doesn't have directions...
It is part of the Network User's Guide (section 10) and the Software User's Guide (section 3 for a PC using Windows, Section 8 for network scanning), not the User's Guide. The directions below are for XP and Win2K primarily. Slight changes may exist with other OS versions. (Full software is not available for Win7 so the buttons on the unit will not work. You will need to launch scans from the computer only. You can use Windows Paint or Fax and Scan without needing third party software. Then attach the file to an email either in the email software or by right clicking on the file and choosing Send to Mail Recipient.)
For either use, put the document face down on the glass or face up in the ADF.
If you use a directly connected computer, you need to set the destination for the Scan to E-mail in the Control Center (section 4-4 in the Software User's Guide). Open this program and make sure the correct machine is in the drop-down menu. This program needs to be running to hear the buttons being pressed. Click on E-mail to set which program will get the scanned document as an attachment for your e-mail. You can also set the resolution and type of attachment. If you do not want to use available file formats, you will need to scan in PaperPort (or other software) and then use that to attach the file to the e-mail. Then click Scan to launch the scan from the unit. Hit Set when ready to send.
If you have the unit set up on the network, then you can enter the LAN setup in the Front Panel (or a browser). Hit Menu 6 (and then the appropriate number for the next feature), such as TCP/IP, DHCP or Static IP (these are under 1), SMTP, POP3, Mail Address (Menu 6 2). Setup the Scan to email with Menu 6 7 1 for color and Menu 6 7 2 for black and white.
This automatically sends the item to the email server or PDF as either a PDF or JPEG. Then you need register the PC that will get the file to the unit, if you use scan to email (PC). (Your version of Windows will matter for exactly where the information is: Control Panel > Scanners and Cameras or Control Panel > Printers and Other Hardware > Scanners and Cameras.) Right click on the icon for the unit and select Properties to see the Network Properties box. Go through all of this set up including the Scan To Button. Then the Control Center will launch the e-mail program when it "hears" you press Scan, select Scan to Email, press Set, then choose PC and press Set again. (or select the destination PC which has e-mail access and press Set again). Scanning will start.
If you have set the POP3 and SMTP servers and the unit can directly access them, then you can scan to e-mail and enter the recipient address. Press Scan, select Scan to Email, press Set, choose Email Server and Press Set again. Adjust the scan quality as desired pressing Set at each step. Once you go through all of the layers, the LCD screen will prompt you for the recipient's email address. Then press Start.
I hope this helps.
Jul 20, 2010 | Brother MFC-8440 All-In-One Laser Printer
How does the 1210 scanner work with Windows 7? I have downloaded the driver for the printer and it works ok, but I cannot use the software for the printer. The copier and the scanner work, but i cannot...
You will have to do a two step process to send a scanned document or image by email; the scan to e-mail button won't work. Scan using either Windows Fax and Scan or Paint. Save your file. Then start (Compose/Write) an e-mail to the person you need to send the document. Click Attach and browse to the location where the scan was saved. The default folder is C:/Users/<user_name>/My Documents/Scanned Documents . Click OK after selecting that image. Finish writing your e-mail and send it.
If you'd like to automatically open the e-mail program, browse to the folder where you saved the fax from Computer (Start button) and right click on the image. Choose Send to Mail Recipient. The new mail compose window should open.
I hope this helps.
(a program like PaperPort may let you send to e-mail recipient without the extra step; however I'm not sure of the details.)
Mar 22, 2010 | HP PSC 1210 All-In-One InkJet Printer
How do i scan a document to email?
Install the cd of HP installation of your printer. If you have installed the software thenQ 1. press the first button on the left of your printer SCAN. The scanner will start and a message will arrear. Do you want to scan another picture? 2. You Press the button DONE on your screen it means NO. 3. HP Immage Zone program appears. 4. you must be able now to see your scanned picture. 5 On your lest bottom of the screen you will see TRANSFER IMAGES and the sign >> downway, press and will appear 3 selections. FROM CAMERA, FROM SCANNER, TO e-mail . 6 press TO e-mail and this is the answer. Now you can send by e-mail what you have scanned!!
Nov 16, 2009 | HP PSC 1315 All-In-One InkJet Printer
I am trying to scan a printed document using my HP PSC 1210xi all-in-one, and when I press the scan button, the On/Resume light will flash for a few seconds, then go solid. Nothing else happens. How do I...
First load the software tha tcome with you all in one in the laptop.
then scan from the laptop instead of from the printer.
Use the all in one icon on the laptop instead.
. then it wil lgive you the optiont o send it toE/mail or where.
Nov 05, 2009 | HP PSC 1210 All-In-One InkJet Printer
Don't know how to use OCR scan function.
Greetings,
i beleive we have the complete setting detail with us.
1. Press the [Send] tab.
2. Press [Address Book] ([File] or [E-mail] also acceptable).
3. Choose an e-mail address. Press [OK].
4. Press [File Format]. Set to [PDF OCR]. Scan Settings
default to 300 x 300 dpi.
5. Choose [Send Settings]. Add [Name] and [Subject]
to the e-mail.
6. Or choose [Doc. Name OCR] to automatically name
document using initial characters of document text.
7. Press [Done].
8. Place the document on the platen glass or in the ADF.
9. Press [Start] to send document.
Regards,
TechSup1
May 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I purchased a HP LaserJet 3050
The instruction to use scanner in HP Laserjet 3050
Click Start, click All Programs or Programs, and then click HP. Click HP LaserJet
3050/3052/3055/3090 all-in-one, and then click Scan.
Click Setup.
Select Change the destinations that show up on the all-in-one control panel when I press
the Scan To button, and click Next.
Select Allow me to scan by pressing the Scan To button on the all-in-one....
Move the destinations from the PC window to the All-in-one window.
Click Update. See the online User Guide for complete information
Source : Manual for HP Laserjet 3050
Thanks for using Fixya
SAM ANDERSON
Sep 11, 2008 | HP LaserJet 3050 All-In-One Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
242 people viewed this question
old marine
old marine
