Question about Konica Minolta DiALTA Di200 Copier
Get code C0b61 on Minolta 4000 copier
It started because of a jam but there is not longer a jam. Tried turning off the power source. Nothing works.
Our minolta 4000 gives cod m3
Posted on Dec 11, 2009
  • gmustafamuja Dec 11, 2009
    fixya is useful to solve problems
  • Konica Minolta Master
  • 1,297 Answers
If posbbile the reset to open and close the front door is OK,if not unplugged the finisher/sorter cords and plugg again.Manually turn the spiral cams in order to check if they rotate smootly.Please check and clean or replace the drive transmiting components or the bin unit motor.
Posted on Aug 19, 2009
  • 6,168 Answers
Check the exit bins mite be jammed. Service manual is Bin movement. Check mvement of all bins open close finiher door and reset front door
Posted on May 10, 2009
How to remove 601 code photo copier Minolta CSPRO 4000
Scanner fault,open the front door upper left should see access cover, open press trouble reset if the code comes back replace
Parts that may need to be replaced
Scanner Motor M4
Power Supply Unit PU 1
 SCP Board PWB-F
 Master Board PWB-A
If you can find these parts you have a legacy Minolta analog copier not even digital
try this as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jan 08, 2016 | Minolta Office Equipment & Supplies
4000 code cooo1
Code is for the main motor. Mite want o check the fuser the hot part for broken gears or jam gears or any gears that drive the drum or developer. Or a bad clutch.
Dec 08, 2013 | Minolta EP4000/5000 CS/PRO Copier
Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Apr 27, 2011 | Minolta EP4000/5000 CS/PRO Copier
Paper jam and give code C0070 at the screen. Model Minolta 4000
Hi this is a standars problem you will need to take apart the back of the toner hopper where the toner goes in the drive motor or worm gears will be damaged and will need to be replaced or the motor some times you just need to clean around the sensor toner hopper sensor and it will fix the issue
Feb 25, 2011 | Minolta EP4000/5000 CS/PRO Copier
Printer was working fine then the error light started to slowly blink. Checked for paper jam and found nothing. Cleared out dust with canned air, still error, shut off then unplugged from usb port and from...
You have to see how the led is blinking and to compare with the table that explains every blink what means. If you don't have this table, contact me and I'll send it to you.
Chip reset device for Konica Minolta Bizhub and CF imaging units
http://www.chipreset.eu
Jul 29, 2009 | Konica Minolta PagePro 1350W Laser Printer
Code C0510 on our Konika Minolta Di 181
Check heater lamp or thermostat might burn out
Mar 04, 2009 | Konica Minolta DiALTA Di200 Copier
How to clear M2 on minolta EP 4000/5000 cs/pro copier pls send solution to michofolasenterprises@yahoo.com
clear web or drum count and developer,you will not effect the the machine aporation,by clearing count
Sep 16, 2008 | Minolta EP4000/5000 CS/PRO Copier
Document jams ep 4000
Ceck the rubber rollers on the doc feeder. They are probably real soft and mushy. If so they need to be replaced!
Dec 14, 2007 | Minolta EP4000/5000 CS/PRO Copier
Konica Minolta DiALTA Di200 Copier Logo
367 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
