Question about HP LaserJet 1200n Printer
Hp laserjet 1200 series streaks down right side of page
My printer is making ink spots and some letters are not printing fully on the right side of the page. It is a new ink cartridge. I have been told it might be the fuse. Is that correct and is there anyway for me to replace this on my own? If yes, where do I get the part?
  • 4 more comments
  • joannestr Mar 05, 2009
    I bought a brand new cartridge and the problem did not correct itself. The small blotches are 1" right of center and evenly spaced down the page. It is not a continuos streak. It is a blotch or a smear every two inches or so.
    What could this be and how can I fix it?
    How do I replace the fuser? Is it difficult?
    Do I need to clean it first? And where do I buy the part?
    Where do you buy a fuser? Not having put a fuser in and how difficult would you imagine that it is to put into the printer?
    Good idea on the service manuel, but where would I buy the part?
  • joannestr Mar 06, 2009
    Thanks for your help.
    Genius:
  • 2,120 Answers
It's a bad toner cartridge, trust me.
Posted on Mar 05, 2009
  • 3 more comments
  • Leroy Elliott
    Leroy Elliott Mar 05, 2009
    The only thing left is the FUSER. The Teflon may be worn off of the rollers causing the toner to stick to them.
  • Leroy Elliott
    Take off the rear cover and have at it. I personally have never done one on that model.
  • Leroy Elliott
    cleaning won't work because it is film (mylar) not actually a roller. you will probably have to buy a whole fuser.
    www.partsurfer.hp.com
  • Leroy Elliott
    Getting the covers off is always the hardest part.
    You could buy a service manual from eBay.
  • Leroy Elliott
Hp laserjet only prints clearly on 1/2 the page
YOU PROBLEM IN THE FUSER STAGE MAYBE FUSER FLIM IS PROBLEM
Mar 28, 2013 | HP LaserJet 1200 Printer
My hp laserjet 1200 series printer will not stop intermittantly printing single pages of a multi page document holtbldr@bellsouth.net
Turn off computer,turn off printer disconnect comm cable for 5 min,reconnect reboot should stop intermitted printing
Jan 18, 2011 | HP LaserJet 1200 Printer
How do i stop my printer from leaving ink streaks down the right side of my pages?
I was going to suggest removing the fuser and looking at the rollers, but on this printer it's a major operation.
Instead let's run the half test. Put paper in the manual feed tray(tray 1). Print to the printer. When the sheet of paper gets pulled about 3/4 of the way in, open the top cover. Pull out the toner cartridge. Look down at the paper. Does it have a streak down the right side? If yes, replace the toner, if no, have the fuser replaced.
Oct 21, 2010 | HP LaserJet P2015dn Printer
Printing a large black streak of toner on rt side of page
Hello! Malik Muhammad Mehran Here... your problem solution is that you must replace the cleaning plates in the cartridge...
Mar 28, 2010 | HP LaserJet 6L Printer
Laserjet 1320 is printing a streak down the left side of the page. I replaced the fuser and toner. What's next?
Checking the paper path for ink deposits might be the solution. I had a similar problem sometime ago, where the fuser got some scratch damage for unknown reasons and i suppose was causing unfused ink to accumulate after the fuser, leaving streaks on paper.
Oct 23, 2009 | HP LaserJet 1320 Printer
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
STREAK LEFT ON RIGHTHAND SIDE OF PRINTED PAGE
Fuser sleeve is contaminated and needs replacing - cheaper to replace the printer.
Apr 16, 2009 | HP LaserJet 1020 Printer
Hp laserjet 1200 series printer prints partially.It prints only the left and right side of the paper but not the middle part. give me a solution
what is the problem actually printing left side or right side or upper down. First check tonner cartridge, if its of then check printer leser unit just clean it again.
Feb 27, 2009 | HP LaserJet 1200 Printer
Printing problem
That is usually an indication the fuser sleeve is worn out or is torn on that side. Start to print a full page and then open the front when the paper is halfway printed, remove the print cartridge and look at the print on the page. If it is good before going into the fuser then you will need to replace the fuser, which is expensive for that model. It is not available from HP any longer, but some places still sell it.
Part Number is:
RG9-1493-060CN
Jan 15, 2009 | HP LaserJet 1200 Printer
HP LaserJet 1200n Printer Logo
255 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
