Question about GE Spectra JBP78 Electric Kitchen Range
Oven does not work
The stove top works but the oven does not,the lights for the oven don't light no digital display nothing.
  • summergrlly Mar 13, 2009
    i have the exact same problem. where do i go to find the parts and about how much should i expect to pay?
  • GE Master
  • 3,361 Answers
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Posted on Mar 04, 2009
4 Suggested Answers
tatunka
  • 85 Answers
SOURCE: oven not working (lighting) on magic chef stove top/oven
look at the burners in the oven,they usually go bad where they hook to the unit,it will look like a peice is missing.if this is not the case, a wire is loose in your breaker and you're running on 110 instead of 220
Posted on Nov 14, 2008
  • 2920 Answers
SOURCE: The digital display does not come on
you have a burnt board thats going to need replacing.that was the pop you heard and the puff of smoke.
Posted on Dec 28, 2008
SOURCE: stove quit working
We had the same problem. But it would turn back on after 20 or so minutes. But as soon as it heated back up to 350 it would shut off completely. I called tech support but only got someone in India who I couldn't understand. Then I called a local technician and they charge a grip just to look at it! I finally got sick of it and banged on the control panel. To my surprise it turned right on and has been working ever since :) *This method is not recommended for use on children or animals.*
Posted on Oct 17, 2009
Westinghouse oven model WFE946SA, purchased only 4 mnths ago. No lights display
main control board,take it back,its expensive,1 year warranty
Jul 26, 2015 | Ovens
The display and buttons are dead, no display or oven lights but electric starter still works on stove top
find the breaker for the stove and turn it off for 2 minutes then back on, if that does not work look on back of stove in area of controles for a small reset button, some time they are hidden just inside a small hole
Jan 09, 2014 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Stove does not work
sounds like youtr circut board is burnd out.also im not sure if youre model but some frigidair stoves had a callback because of the short problem .the were seting houses on fire.call youre local appliance dealer and see if youre model falls under this catigory.if i were you i would not use this unit it could result in a electricle fire untill you contact local dealer.
Apr 07, 2013 | Kitchen Ranges
Both lights on the top oven work when using it as an oven but when using it as a grill, they don't! There doesn't appear to be any other fault as the oven and grill still work fine. Any thoughts...
The unit is working as it should. The top oven lights will only come on when the top oven control knob is turned on. The grill control does NOT turn the lights on. If you want to see what you are grilling, then you should turn the top oven control on to its first position. This works even if the grill is operating.
May 10, 2011 | Stoves 720EF Electric Double Oven
Dec 28, 2008 | Kitchen Ranges
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Oven fuse blows - Nothing works
try lifting the stove top assy and checking wires under main top, leading to the elements them selves??? if tis tripping and not allowing to reset its gotta be an obvious short. isit hard wired directly to stove or into a 220 cord and plug???id look again, perhaps remove entire back panel and have someone trip on the breaker you might see where it flashes as it trips off
Apr 03, 2008 | Tappan TEF242 Electric Kitchen Range
Oven stopped working while cooking a meal
it sounds like it burnt one of your main wires in the back of range. by turning a knob on you are getting a feed back. turn the power off remove back panel take a visual check of your wiring.
Nov 23, 2007 | GE Profile JKP18 Electric Single Oven
GE Spectra JBP78 Electric Kitchen Range Logo
308 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
