Question about Refrigerators
GAGGENAU Refrigerator IK300-254/21 - Service manual.
I have a Gaggenau refrigerator/freezer model IK300-254/21 and I am looking for the service manual in order to restore the PC board original parameter settings, which have been tempered with by previous owner.
Alternatively a list of the setting values for parameter nos. 0 to 82 with index discribing their function will also be helpful.
  • Anonymous Apr 20, 2009
    Also looking for the service manual
5 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Looking for owners manual on
try putting your model number in here( a sears sigth, if you cant get it this way try calling sears direct and they should be able to get you one
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 30, 2008
SOURCE: how to set the thermostat? gaggenau fridge freezer
how to set thermostat on double door fridge freezer
Posted on Dec 09, 2008
woodchuck789
  • 4059 Answers
SOURCE: Need a service/repair manual for a Kenmore refrigerator.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 4 on this diagram is your timer http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=1069608210&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&diagramPageId=00003&componentDescription=COMPARTMENT%20SEPARATOR%20AND%20CONTROL&documentId=00050440&backToLink=Return%20to%20subcomponent%20list
Posted on Aug 13, 2009
tbirdfan1
  • 3051 Answers
SOURCE: refrigerator not cooling - freezer is very cold
Hello there:
There are several different things that could make your refrigerator not cool properly.
I have compiled a list of things that you should check out and how to check them ok
It's not cool If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running. First, answer these questions: Is the refrigerator completely dead? If so, Is the thermostat knob turned to the proper setting? If not, reset it. Next, see if the compressor motor is running The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help. If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these: The compressor The Thermostat The overload, relay, or capacitor The defrost timer The condenser fan motor Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas: Evaporator coils Condenser Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
I will continue the rest of the post in a seperate post to allow for full detailed instructins
Posted on Apr 15, 2010
  • 351 Answers
SOURCE: I have a GE Profile side be side refrigerator
hi sound like you have a bad damper. the damper is in the top of the refrigerator side from middle to left
Posted on Oct 19, 2010
Service manual for gaggenau 27L microwave oven
If you Google Gaggenau, you should find their Web site. Then look for support links in your country.
Dec 11, 2012 | Microwave Ovens
Parts manual for Gaggenau VF 112 Deep Fryer.
Hello, To download the files you need the E-Nr. (WM204140/01). You can find the number on the label inside the appliance or on the appliance door. I went on the gaggenau site and even with entering a couple key numbers as we have done before it is not recongizeing the VF 112 and asks for more information about the model number. I will need the complete model number. Also I am assuming even though you have this posted for the VF 230 that you are looking for the VF112 from you statement. I will post this response as well as a couple more informative things about Gaggenau as well. I await your reply.
Thank you,
Rick
Nov 22, 2011 | Gaggenau VF 230 Deep Fryer
Gaggenau Wall Convection Oven EB 270 installation instrutions and electrical hook up.
http://www.gaggenau.com/US_en/service.do
you can download installations and user manuals from this site. You'd probably be better putting the full Enr (model) number in the search.
Click where it says 'All manuals available for download' this will open a window where you type in the model. You then get a long list of manual, I presume you want it in english, so pick the one that had EN in the first column and II (installation instructions) in the next column.
Hope the is what you're looking for, all the best.
Jul 05, 2010 | Gaggenau EB 270/271 Electric Single Oven
Lost instructions need help use of rotisserie in my to oven
click on link, click on 'all manuals available for download', anew window will open, type in your model and choose the language and manual you require IU is user manual, ii is installation manual.
Hope this helps
May 19, 2010 | Gaggenau EB 294 Aluminum Double Oven
How to set the thermostat? gaggenau fridge freezer
Nov 24, 2008 | Gaggenau Refrigerators
Single oven door latch is broken
hi we sell gaggenau parts but we are in the uk sales@gwhitedist.co.uk
May 04, 2008 | Gaggenau EB 270/271 Electric Single Oven
Refrigerators Logo
922 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Gere knutson
