Question about HP Compaq Presario V6105NR Notebook
V6105NR MICROPHONES DO NOT TRANSMIT
I have a HP V6105NR with build in microphones. I was on skype making a phone call and my microphones were not working they could not hear my voice
  • 408 Answers
Does your microphone work with other applications.  If you are running windows XP, go to Start>all programs>accessories>entertainment>sound recorder.  Record your self and play it back.  If you can hear yourself, then the issue is with skype.  Make sure you go through the audio setup wizard in skype to get the best preformace out of your microphone.  If no other programs work, then you may need to reinstall the drivers for that microphone and try it again.
Posted on Mar 04, 2009
I have a Pavilion dv6-3025dx and cannot get the sound to work for skype. Obviously there is a camera and that works fine but I could not get the audio to work - do I have to add a microphone. Can you help?
I understand that you are not able to us the microphone with Skype. As per the information provided in User Guide for the model it seems that the model has an Internal microphones .
Try configuring the internet microphone to use with Skype.
Open Skype - Tools - options- Audio settings- Set the input device as internal microphone and check the operation.
Aug 22, 2011 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
Can you pls let me know how do I fix my laptop microphone (HP Pavillion dv1000); when using skype others cannot hear me (or when I do the test on skype, I cannot hear my own message). I have checked the...
Assuming you are using Windows 7
<Start>, <Cotrol Panel>, <Ease of Access>, <Speech Recognition>, <Set up Microphone> Follow prompts and instructions. Once your Microphone is set up, your Skype will work.
Mar 20, 2011 | HP Pavilion dv1000 Notebook
How do I unmute my microphone on skype?
Solution for Skype 5.0:
In the upper right of the window during a Skype call, there should be an icon of a microphone with a slash through it. When it is highlighted in red, this means that your microphone is muted. Make sure the icon is white to be unmuted (pictures below).
Another problem could be which microphone you have selected in your Preferences. Go to Skype->Preferences... and click on the Audio/Video tab. There should be a drop down menu labeled "Microphone:"; make sure the correct microphone is chosen.
Feb 26, 2011 | Audio Players & Recorders
I changed from vista to 07 and installed skype, i did my self voice test and i can hear but cannot transmit voice via my microphone, please help me out
a ) There is manual inside the link on your other post for your mic .
might need to download , and read it.
b ) if you are successful on step 1 ( your other post )
then on your Skype browser it might look like these :
To get to these settings :
1 ) Click on "Tools " then " Options " then " Audio Settings ".
2 ) Then you can adjust the mic level to work.
Note: the Audio Device may not be the same as yours ( sample only )
hope these helps
Nov 23, 2010 | Dynex Voice-Certified PC Desktop...
Does the 1030NR netbook have a built in micro-phone? If yes, How do I activate it for Skype use?
No, there is no built-in microphone on your machine, you have to buy one separately.
NB! It requires a combined headphone/microphone jack. The regular jacks work for the headphones, however the microphones will not work.
See here
Apr 11, 2010 | HP Compaq Presario CQ50-103NR Notebook PC
I skpe using my Asus, and my microphone does not work.The other party can't me...how do I solve this please
Hi
Are you sure that this laptop has a build in microphone? or are you using a external microphone?
in either case the most likely problem is that the skype sound settings on the input are wrong.
open skype, tools, options, then the audio settings page.
On the microphone, try all the possible options offered and see if it detects your voice, you can also try calling the skype test number / echo123.
When you see the volume bar light up green like this as you speak or tap the microphone its working.
If you are using a external microphone, are you sure you have it on the right slot? Try the other plugs on the laptop and then go over the options again and see if you get sound.
You should also check from volume control that the microphone is not muted.
To check that open up start -> control panel -> sounds -> recording -> select the microphone and click properties -> check the levels tap and make sure its not muted and its turned up to full volume.
also some microphones have a on off switch on the wire, make sure its turned on.
By now you should be able to talk on skype.
Let me know if you need further assistance.
Thanks,
Ekse
Aug 13, 2009 | ASUS m6n Notebook
No sound when I turn my computer on/0ff, no sound on skybe,
try to test your microphone settings in the control pannel and perform sound test in skype.
Jul 28, 2009 | Audio Players & Recorders
Built in Microphone Logitech S5500
go to properties..you can either choose to work with build in mic or external.simply highlight input source and you are ready to go...
good luck
Jul 18, 2009 | Logitech Audio Players & Recorders
About my microphone
make sure your audio device is selected, the one that you are using such as a usb phone over your onboard realtek audio.
Aug 19, 2008 | Shure Head Set Microphone Microphone
Utilizing two microphones
No, when you buy multiple wireless mics you have to select different channels per unit if you want to use them on the same stage.
hope this helps
thanks for your rating
Jan 09, 2008 | AKG (WMS40DIV444US54) Microphone
HP Compaq Presario V6105NR Notebook Logo
194 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
