put cd in tray, tried to listen to it, wouldn't work, can't get cd back out. the tray spins all the way around, but makes some scraping noises. this is a 6 disc carousel cd changer. anyone know any tricks to get the cd out?
CD won't release from player. I took the top off and discovered that the small belt was brocken (like a rubber band) which connects the motor to the CD lift and play mechanism. Now i need to find a new belt or rubber band to substitute.
Best Solution
posted on Aug 08, 2005
Bomber - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
Unplug it, take the top off (usually four screws, two in each side...sometimes one or more in the back), retrieve your CD. For some reason, it's not on the tray anymore. The scraping noises are from some movable part contacting the CD. That's dangerous to the CD and possibly the mechanism.
My daughter once moved her stereo to another room and asked me to hook it back up for her. I did, and upon powering up the system, the CD carousel started making a racket and wouldn't play. She had carried the unit up the stairs fully loaded with five disks. They got caught in the mechanism and trashed a couple, along with a small plastic tab on the changer itself. I had to do some creative fabrication of parts in order to get it to work again.
Unplug it now....
jak
Was this solution helpful? Show your Appreciation by rating it:
My CD player suddenly stopped playing. It cycled without recognizing any CDs in the 6 CD disc cartridge (box/holder.) I discovered a CD had gotten stuck inside the CD player beyond reach, it was wedged inside. It somehow got out of the 6 CD disc cartridge and prevented the recognition of discs in the cartridge; the unit made a funny sound in cycling fruitlessly from disc to disc.
After removing the CD holder, I quickly shut off the power to the unit to prevent the door from closing automatically. With the door open, I could work on it. A nice size silicone spatula from my kitchen was flexible, pliable and long enough to get to the disc, straighten it from it's lopsided position and slide it out enough to get it out with my hand. I think had I not tried the maneuver first with a chopstick (to no avail) the CD would probably have come out intact. It ended up with a few scratches but the unit works again like before. I avoided a hefty repair charge and/or having to buy a new unit. My unit is a Philips/Magnavox CDB 586 (6 CD changer.)
Show your appreciation by commenting on CD Stuck in CD Player Onkyo DX-C340:
Solution #3
Jimmy NY - usenet poster
Hi Sureshot :)
Dunno about your changer; but perhaps worth mentioning anyway.
Take a look at the front of the unit, near to but not on the tray itself. See if there isn't a tiny hole there - about a sixteenth of an inch.
If you're lucky and there is, you can put something like a very small jeweller's screwdriver, or a long thin finishing nail into it and push. The drawer should open for you.
Take care.
Ken
Solution #4
pandamama - usenet poster
You might want to take the cover off the unit and retrieve your CD. It may have fallen from the carousel somehow. Just don't force anything.
These players usually won't open until the turntable is properly aligned with the traverse unit (playing mechanism), and the traverse unit has been lowered out of the way. If you're hearing rotation, the unit is in the lower position already.
The sensing devices that determine the table position may not be functioning. The most common cause is a defect in the "flexy" cable from the drawer to the main PCB.
If the trouble is more involved than just an out-of-place CD, be kind to your Onkyo and take it to a repair shop. It doesn't sound like a real serious (expensive) problem.
Good Luck
Doug
