Question about Campbell Hausfeld Airless Spray Guns & Accessories Airless Sprayer 0.42 Gpm, 2/3 Hp, 50 Foot Hose, S150G Gun, X Tip & Filter, Sv Cart
Still wont prime new packing new check balls dont know what else to do it is a spraytech ep2105
  • 26 Answers
Wish i could offer better advice but call tech support, they are usually pretty helpful with this... theyll talk you through..good luck
Posted on May 02, 2009
My 440e wont prime.took most of it apart and cleaned out old dried up paint,cleaned prime hose as well but it still wont prime.help please!
If the advice so far doesn't solve the problem, you probably need to change the packings. Its easy to do yourself and the kit comes with instructions. While you have the pump apart, check that the piston is not worn or damaged. If it is worn and needs replacing you may see that the hard chrome has worn through to the steel, or there's a noticable ridge where the piston stops; if it is scored it will ruin the new packings. Be sure to install the packings with the lips facing in towards the pressure (top packings lips down, bottom lips up), and use the insertion tool that comes with the kit to push the piston through the top packings.
Apr 04, 2014 | Titan Epic 440e Outlet Valve Seat 700-609
Won't prime
You either have a stuck ball valve, or a leak in the paint suction
Feb 09, 2014 | Wagner SprayTech Wagner Airless Paint...
Unit won't prime,
YOU HAVE A STUCK INLET BALL
Have the unit in water, pressure relief valve turn the machine on and tap with a hammer at the inlet ball, This frees it up 90 of the time.
Otherwise the machine need to be disassemble
Jan 29, 2014 | Wagner SprayTech Wagner Airless Paint...
Will not prime
Most of the time when a unit will not prime it is because of a stuck inlet ball, I would put the intake in water turn the machine on to bleed. Then tap the machine where the paint comes in. 90% of the time this will get it going. Sometime you can stick a screw driver into the inlet ball and free it up. If this doe not work you need to take the machine apart and cleanor you have worn out packing.
Joe
Jan 23, 2014 | Wagner SprayTech Wagner Airless Paint...
My spraytech 1620 wont stay primed,and it's not the ball..what do i need to do or buy for it ????
It was probably from Home Depot,was it a refurbished unit as Home Depot will just do a basic flush and lube the fittings/seals..try getting a repack kit from them.
Oct 19, 2012 | 1620
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
Spray gun wont stop spray when trigger is released
There is an adjustment nut on the back of the neddle but most likely is it wasn't cleaner the last time it was used. Take off the tip houseing then re move the nut on the front of the gun thats the seat for the carbide ball on the front of the neddle re move the neddle and clean all parts in laquor thinner then it should work
Dec 17, 2010 | Wagner GX10 Spraytech Airless Spray Gun...
Ball will not prime
you can check the filter in the tank just blow the filter out if that don't work check the lines going to the bulb if you have change the bulb out change the lines around
Jun 27, 2009 | Echo Rapid Loader, Trimmer Head
Campbell Hausfeld Airless Spray Guns & Accessories Airless Sprayer 0.42 Gpm, 2/3 Hp, 50 Foot Hose, S150G Gun, X Tip & Filter, Sv Cart Logo
932 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
john h
JOHN LAPIER
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
