Question about Cameras
Element Electronics 9 Digital Photo Frame 1/2 screen shows
I have a Element Electronics 9'' Digital Photo frame Model E9WDPF just bought a Circuit City Going Out of Business sale. When I brought it home and showed my picutures, only a half screen shows the picture. The other half if all lines. No exchanges allowed at Circuit City. Am I out of luck.
F
    Problem Solver:
  • 12 Answers
SEE IF YOUR PHOTO FRAME HAS A "VIDEO OUT" IF SO TRY SHOWING PHOTOS ON YOUR TV.
Posted on Mar 07, 2009
How do I get my sylvania 10 in. Photo frame video intensity increased
Image Settings; Calendar Settings - Sylvania SDPF751B ...
www.manualslib.com > ... > SDPF751B > User manual
Sylvania digital photo frame user manual. Hide thumbs. 1 · 2 · 3 · 4 · 5 · 6 · 7 · 8 · 9 ·10 ... You can decrease/increase the value by pressing. Time: Press to set Date, time. ... Digital Photo Frame Sylvania SDPF733 User Manual. Sylvania digital ...
Electronics - Sylvania
Dec 10, 2015 | Sylvania Cameras
Sylvania photo frame screen won't come on
No brainer back light on photo frame is no good.
Been there. done that trashed it. I lost reciept.
Dec 20, 2013 | Cameras
PANDIGITAL Digital Photo Frame works perfectly except the SCREEN Flickers Black after a few moments
Annemarie, I had a similar problem with an off-brand photo frame from Wal-Mart last year, although in my case the frame would shut down entirely after it had flickered a few times. In my case, I was able to remove the back of the frame's case by removing 4 screws (two were hidden underneath model number stickers) and inspecting the device's innards... what I found was that, as you surmised, there was a loose connection from the female end of the DC-in power supply. The ground connection to the device's circuit board had been poorly soldered, leaving the connection itself loose and a small piece of solder on top of the board and very near the positive connection.
While not being the best solderer in the world, with the aid of a magnifying glass, a solder removal tool, and a ColdHeat soldering wand, I was able to heat the offending piece of solder and remove it from the circuit board and then, as I was personally uncertain of my ability to re-solder the connection without melting the board, I simply held the connection in place and applied a dab of hot glue to keep it there. After the glue cooled, I reassembled the case and the frame worked for almost another year before something else finally burned out and it was left cold and dark.
Hope this helps, good luck!
Dec 03, 2013 | PANDIGITAL 7-Inch Digital Photo Frame with...
Need instruction info.
Step 1: Determine the make and model of your 9" digital photo frame.
Step 2: Post your question in the "Digital Camera Accessories" or "Photography Accessories" section of FixYa instead of the "GPS Devices" section. When you do, please make sure to include the information from Step 1.
Dec 31, 2011 | GPS
My digital photo frame screen is black. I have checked the AC adaptor on another frame that I bought at the same time and it is transmitting current. It is a smartparts frame SP1000EF, Model no....
It tends to be the problem of internal circuit board in digital photo frame .If the adaptor is working fine with other digital photo frame then definitely it is problem of internal connection . So better replace the unit if it is under warranty . Else one more try is just tap on the sides of photoframe when you power on the unit .
Hope this helps .
Apr 22, 2010 | Smart Parts Digital Picture Frame
Frozen Screen on Digital Photo Frame
I have the same problem!!!
Did your frame already work?
Feb 15, 2010 | Philips 6.5-Inch Digital Photo Frame...
Images from memory stick will show on frame but
Try these steps: 1. Insert the card.
2. Tap on MENU.
3. Select PICTURES and tap on OK.
4. Highlight SD/MMC and hit OK.
5. Once you see the thumbnails of the pictures, tap on MENU again.
6. Scroll down to MULTI-SELECT and hit OK.
7. Tap on MENU and scroll down to SELECT ALL and hit OK.
8. Tap on MENU and scroll down to COPY and hit OK.
9. Highlight INTERNAL MEMORY and hit on OK.
Dec 18, 2009 | Kodak 8" LCD Digital Photo Frame
Need english manual for 512 mb 7" LCD
[PDF] 7Digital Photo Frame User Manual File Format: PDF/Adobe Acrobat - View as HTML
Digital Photo Frame. Please read carefully and follow all warnings and instructions in this User's ... Product: 7”LCD Screen Digital Photo Picture Frame ...
www.x-digitalmedia.com/PDFs/7inch.pdf - Similar pages
May 07, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
Digital Picture Frame Shows Black Bars
The nature of 16:9 basically means that you will be losing photo information in normally framed 4x5/5x7 photos. There is no way to fix this because the frame size of 16:9 is wider than 4x5/5x7. The options the frame offers are the only options to make your photos fit. Either crop, or distort.
The best solution is to keep this in mind when taking photos from now on and assume you will be cropping the top and bottom of the image.
As for the photos you have already taken, the only viable tactic to take is to reframe them for 16:9 yourself. You can download a free photo editing application like "GIMP" to do this. Create a new project that is 800x450 pixels. This will give you a 16:9 canvas. Next drag your existing photos into this canvas and move it around and resize it until you find a suitable framing for your picture.
Unfortunately it seems that as 16:9 solidifies itself as the new screen standard people are finding that shooting photos framed for 4:3 or in portrait dimensions are not translating well to this new standard. You may even want to consider returning this frame and looking for a 4:3 aspect ratio frame if cropping/resizing is not acceptable for you. Good luck!
Jan 03, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Cameras Logo
249 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
