Question about Saeco Magic Comfort Plus Espresso Machine
Steamed milk is not coming out - Saeco Magic Comfort Plus Espresso Machine
    Problem Solver:
  • 14 Answers
Clean the steam wand, it unscrews and needs to be cleaned, also, descale the machine once the blocked tube is cleaned. When milk dries it is like glue and clogs the steam wand. so clean it daily after use.
Also, I think you meant to say, steam for milk frothing is not coming out. If you meant steamed milk is not coming out, it's not supposed to do that. Some Saeco's can add an attachment called a milk island but not the magic comfort plus.
Posted on Apr 22, 2009
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
Are there different types of espresso coffee?
The classic form of espresso is a small shot (2-3oz) of pressure brewed coffee made using about 1tblspn of finely ground coffee. There are several ways in which this original format has been altered to come up with various types of espresso coffee drinks. Here is a short list of some of the more popular varieties:
Americano - espresso with hot water added to dilute the strength
Macchiato - espresso shot with a small amount of frothed milk on top
Corretto - espresso mixed with a bit of alcohol
Cappuccino - a shot of espresso topped with 1/3 steamed milk and 1/3 frothed milk
Mocha - a latte with chocolate powder/chocolate sauce added
If you would like to know more about espresso, please visit the link below.
http://www.1stincoffee.com/what-is-espresso.htm
Feb 07, 2013 | Wine & Spirits
Despite having thoroughly cleaned the cappucinator and descaling the system recently, we just don't seem to get real steamed foam. It appears to be just hot milk with a few bubbles on the top.
when you remove the cappucinotore, there is a little clear plastic tube sticking up from the top of it. this is an air entrance oriface. this is where the air is brought into the steamed milk in order to froth it. the hole is very small, like the size of a hair. You need to clean this, or if you cant get it clean, your machine came with a spare one. It was in the cardboard box with the cleaning tablets, o rings, and descale tabs. Once this is clean, air bubbles can get into the milk and you should have nice foam. let me know if that doesnt work.
May 15, 2011 | Miele CVA4070 Coffee Maker
What does it mean by 1/3 expresso, 1/3 steam milk and 1/3 frothed milk? 1/3 cup...1/3 teaspoon??????? New to this. what are measurements
i'm sure it is referring to total volume, that being 1/3 of your total is expresso, 1/3 of total volume is steamed milk, etc etc. it is not really a measurement but a ratio of the different components of the drink you are making, example,,, chocolate milk might be 1/4 chocolate and 3/4 milk. if you were making it it would take 1/4 of the "mug" you ar using filled with chocolate, the rest or 3/4 filled with milk. make sense?
Jan 17, 2011 | Microwave Ovens
I just need to know how to make a cappuccino useing my DeLonghi Cafe Sorrento. Thanking you
Cappuccino is a mixture of espresso, a little steamed milk and a little milk foam. The milk/foam ratio is up to you what you enjoy most. Some like a thick layer of foam while others just want foam as a garnish on top. Mix as you please.
Feb 22, 2010 | DeLonghi Cafe Sorrento Espresso Machine
The steam coming out of my espresso smells burned
Try descaling amchine to clean boiler.
Mar 12, 2009 | Saeco VIA Venezia
Lousy foam!
Perform a full descale cycle to clear the steam boiler of any debris or build up. Most likely due to blockage.
Jan 23, 2018 | Saeco Royal Exclusive 30153 Espresso...
Steamed milk
I've just taken delivery of an S9 and my lattes were lukewarm too. What you have to do is move the dial on the steamer to the 3 o clock position. See http://cdn2.libsyn.com/coffeegeek/jura_frothxpress.mov?nvb=20081110133816&nva=20081111133816&t=018ee7ad85c33f422c6a5 . Latte I just made was piping hot. If that doesn't fix it, try the Products settings. If still lukewarm I think you should contact your dealer, maybe you have a duff machine.
Oct 18, 2008 | Jura Capresso Impressa X90 Espresso...
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Steamed milk
I just had this same problem and solved it.  It was due to a very small amount of milk residue on the inside of the black frothing unit (the one with the dial which lets you choose foam or no foam).  Grip the dial firmly and pull it out while twisting. It may take a few seconds to twist and pull it out.  I had a very small spec of milk residue in one of the crevices on this piece.  Quick clean with a toothpick and plenty of hot water, reassembled, and it works perfectly.  Hope this helps someone.
Nov 05, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Saeco Magic Comfort Plus Espresso Machine Logo
386 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
