Question about Konica Minolta bizhub C351 All-In-One Laser Printer
Imaging units bad and no money
I have a bad imaging unit but no money or service agreement. Can I get the machine to be a black ink only machine?
    Genius:
  • 2,120 Answers
No
Posted on Mar 05, 2009
Error c2652 in konica minolta c250
C - 2651 Cyan imaging unit EEPROM acces error
C - 2652 Magenta imaging unit EEPROM acces error
C - 2653 Yellow imaging unit EEPROM acces error
C - 2654 Black imaging unit EEPROM acces error.
Clean the connection between the imaging unit and the machine if dirty.Reinstall imaging unit or change imaging unit.
Try reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON the copier.
Keep pressed the Utility key when the Trouble resest message is displayed.
Release the Utility key and touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Apr 16, 2013 | Konica Minolta bizhub C250 All-In-One...
My black ink is really faded. I installed a new cartridge but the black ink is still the same. The color ones work great, but most of my printing is with the black ink.
Sounds like toner build up on your developer blades in the imaging unit. If the black look like this:
The problem is with the developer in the imaging unit. The problem can be fixed by either replacing the imaging unit for $100+ or you can fix it yourself by cleaning the imaging unit. You will need simple hand tools and if you are careful restore the print quality of your printer. I have a link to instructions that should help you http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300 Hope this helps you.
May 18, 2011 | Samsung CLP 300 Laser Printer
I have a Konica Minolta BizHub C252. In the bottom of my screen on the machine it has a triangle and once I tap it it brings me to another screen and it says: Machine status P 8 P 21 I have no idea what...
P-8 is for yellow imaging unit failure. P-21 is for Color Shift Test Pattern failure. The P-21 Color Shift Test pattern failure is probably being caused by the Yellow Imaging Unit Failure. Basically, I think your issue is with the yellow imaging unit. If you are experianced with these then you could try removing and re-installing the yellow imaging unit. You may have to replace it. I would certainly start there. Or if you have a service agreement then call them out for repair.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 29, 2010 | Konica Minolta bizhub C250 All-In-One...
THE QUALITY OF PRINT FROM MY SAMSUNG CLP300 HAS BECOME POOR, WITH SOME BLACK INK FADED
If the print is faded down the length of the page, then the problem lies within the imaging unit. This is a very commn problem with this printer. The developer blades get blocked by a coating of toner, which after many prints, cause a noticable fade in the image. This can be fixed by replacing the imaging unit or the blades can be cleaned. I have detail instruction in my tips section. It can be done quite easily if you are handy, and you could save yourself some money by not buying a new imaging unit.
Apr 22, 2010 | Samsung CLP 300 Laser Printer
My samsung clx-3160 colour laser printer does not print very well.all prints are barely neglible and now most times no print or characters appear.I have installed new ink cartridges.Please advise.
If the problem is only with Black output you need to change the Black developer of the Imaging Unit, Else you need to refer to the Authorised Service center. Else you may change the complete imaging unit by yourself.
Jun 29, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Error message imaging unit is out
Hi rmcday: Here your problem. The imaging unit creates the image using an electro-photo process. The imaging unit consists of the following: ■ An OPC Drum ■ Waste Toner Assembly ■ Charge Roller Assembly 9.0 Consumables, Routine Maintenance Items and Options Item Life based on 5% coverage Part No. Replaceable by Black Standard Toner Cartridge Black High capacity 3,000 7,000 106R00679 106R00684 User replaceable Cyan Standard Toner Cartridge Cyan High capacity 2,000 5,000 106R00676 106R00680 User replaceable Yellow Standard Toner Cartridge Yellow High capacity 2,000 5,000 106R00678 106R00682 User replaceable Magenta Standard Toner Cartridge Magenta High capacity 2,000 5,000 106R00677 106R00681 User replaceable Imaging Unit 50,000 images 108R00593 User replaceable Transfer Belt 50,000 images 108R00594 User replaceable 500-Sheet Feeder N/A 119650600 Waste Toner Cartridge 3,000 to 5,000 pages (color 5%) 106R00683 User replaceable. Your imaging unit may have exeeded it life of 50,000 pages and will need to be replaced. Hope this helps
Jun 10, 2009 | Xerox Phaser 6120/YN Laser Printer
Grainy image quality on my Phaser 7750
Try something, Send a job with 5 pages to it.
Shut the machine off as a page it halfway out of the exit area.. Open the machine and look at the jammed copies. Are they clear in the imaging unit areas but not upon exiting the machine?
If the image is clear around the drums and imaging unit, then the problem would be in the fuser. If the image is grainy and fuzzy in the image area, You could have a bad second BTR roller, the soft black roller on the left side door. One of the developer housings could be bad. You have to remove the imaging units and look in the opening with a flashlight to see if the developer housing brush is thick on the developer roll.
Could have a bad transfer belt or one of the color housings could be bad.
Less likely is a bad laser. But have you taken the wand that is on the front cover and cleaned the laser exposure slots?
May 14, 2009 | Xerox Phaser 7750DN Laser Printer
Replaced imaging unit but error message still appears calling for service
plug the machine for 20 sec ,and plug it back in than make sure the imaging unit is inserted in corect.if all fail,that mean s you have a bad or used imaging uint..
Apr 23, 2009 | Office Equipment & Supplies
Error c710
Your problem could be one of several things:
1) The Carrier (iron filings) inside the imaging unit is deteriorated and needs to be replaced.
2) The Toner sensor inside the imaging unit may be giving an incoorect reading, due to be faulty or because of old toner/carrier mix blockage close to sensor. Give the imaging unit a good service and replace the carrier.
3) The wires behind the black cover of the imaging unit have been picnhed and is shorting on the metal plate
4) The main PCB of the machine could be faulty
May 27, 2008 | Office Equipment & Supplies
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
95 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
