Door opens, but will not close
SOURCE: garage door close but motor keeps running
The close setting limit switch needs adjusted. Once it is adjusted it should work just fine.
SOURCE: My garage door opener won't close the garage door.
Most likely your door sensors have been bumped and are not aligned properly. Make sure they are pointed at one another and the small light on each one is lit and not blinking.
SOURCE: Garage door opener won't open or close door
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
SOURCE: garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
