Question about Toshiba 57H83 TV
Speaker grille for a Toshiba 57hx83 projection tv?
I need a new Speaker grille for a Toshiba 57hx83 projection tv. Where can I buy this?
  • 10,594 Answers
Required speaker grille available in Part Store.
Posted on Mar 04, 2009
Toshiba 57HX83 57 in. Rear Projection HDTV-Ready Television
With the back off you should be able to see the three large round lens this set should have---black cylinders with a glass lens--if real dirty they can cause picture to look darker and dull---I presume same with DVD player etc connected to rear input.
the lens point up so get dusty, the mirror points down at a angle and rarely needs cleaning.
Jun 01, 2012 | Toshiba 57HX83 57" Rear Projection...
Does this tv need to have a digital tuner attached to it? or is it ready to use?
You need a HD cable box or go Satellite. That is a monitor set with NO tuner. FYI, the older sets that say HD Ready means No tuner. Salesman jumped all over that one when it came out. They would say Yep! it's HD ready and then jump into all the features to side track the customer, it was terrible.
Dec 04, 2010 | Toshiba 57HX83 57" Rear Projection...
The screen is scratched and stained- I would like
that is a good idea, but expensive.
if the screen is that bad, you may want to try with some commercial available polish for glass or plastic, like plast-x. you can get that in any auto parts store or your local walmart...
http://i93.photobucket.com/albums/l72/NoTwilight/temp/PlastX.jpg
Apr 23, 2010 | Toshiba 57HX83 57" Rear Projection...
I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Apr 01, 2009 | Toshiba TP50G60 50" Rear Projection...
There are no screws on the speaker grill of this particular model
If it is KP-51HW40 Sony TV
Speaker grill has 2 caps covering 2 screws at bottom of speaker grill.
Below is an image showing caps of speaker grill that might help you to open it.
Feb 13, 2009 | Sony KP-51HW40 51" Rear Projection...
HELP
when you say flash and went black do you meen after you turned it on it turned off does it do this every time you turn it on? or does it not come on at all
Jun 04, 2008 | Toshiba 57HX83 57" Rear Projection...
Toshiba 57H83 rear projction tv
are you talking about the plexiglass glare screen?...or something else?...
i was trying to find this out in your previous post about this set...
Jun 03, 2008 | Toshiba 57HX83 57" Rear Projection...
Toshiba 65Hx81 model rear projection
The picture tubes dim over time. It's possible they need to be replaced and/or cleaned. There are 3 of them (one blue, one red, and one green).
Jan 28, 2008 | Toshiba 65HX81 65" Rear Projection...
Toshiba tv-model tz55v61
If the red,green and blue mixture adjustment is what you want...
remove front lower speaker grill & access panel..locate RGB
adjust on Screen / focus block.......slightly adjust screen controls for best mixture....do not adjust focus controls.....T.
Jan 10, 2008 | Toshiba TZ55V61 55" Rear Projection...
Toshiba 57H83 TV Logo
164 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
