Question about GE Spacemaker JVM1640SJ Microwave Oven
Metal rack inserted backwards
I put metal rack in backwards and burned the interior of the microwave. Is there a repair kit for the interior to touch up the burnt spot?
  • GE Master
  • 9,098 Answers
It will just have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Mar 06, 2009
Sparks when cooking
Make sure no metal item (forks-spoons or oven rack) is touching the outer wall of the microwave. That will cause sparks. If all that is OK then there is usually a metal fan type blade in the microwave top called a stirrer blade that may be out of place and rubbing the cavity causing sparks. Try to pin point the spark area so you know where to look for the problem. Sparks usually mean metal is touching metal somewhere.
Mar 29, 2015 | Whirlpool MH7135XE Microwave Oven
Maytag Microwave MMV5207AAQ
its common to all ovens! causes are food spills and oil spills left uncleaned! painting only might fix the problem for a while, but it won't give you a lasting service!!
! you should buy a new rack for much safer use!
keep in mind also to clean the oven after every use! (let it cool first of course!)
Dec 09, 2007 | Microwave Ovens
JVM 250vwoo1
Pry off plastic tab. Clean up burn marks with sand paper and touchup paint. Order a new rack clip. Also clean any burn residue off rack.
MOST IMPORTANT: After the repair, do not put the rack back in unless you are cooking on it. Running the microwave with nothing on the rack is what causes this to happen.
Sep 05, 2014 | GE Microwave Ovens
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
Rack Support
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
Put A foil pan in it to warm and now has a burning smell and makes a noise, not heating. assume we blew something Sharp R-7A85
Never, never, never, never, never put anything metal in a microwave oven! No metal, no pot or pan, no silverware, no plate with metal trim ... nothing! No "Jiffy Pop" (comes in a metal container). Use ONLY microwave safe containers. Some claim there are health concerns (dangers) to using anything plastic in a microwave. The claim is the chemicals in the plastic which were not meant to be consumed are consumed as they are burned out of the plastic into the food. These chemicals are know to some to be cancer causing. I am not making this claim ... only passing on what I have heard about plastics. For myself, I don't use plastic or paper (fire hazard) in the microwave. For one thing, I don't like the taste of food that has been prepared or reheated in a microwave in a plastic container - particularly coffee.
Having said that ... here is what is going on. You probably reflected microwave back into the magnatron and ... well ... cooked it. In my area, such damage is not economically repairable. The tech wants $100.00 to look at it, magnatrons are typically $50 to $100 or more. There could also be other damaged parts ... repair bill could be more than a replacement oven.
If you find a oven that comes with a rack, here is how that works. You will observe that the rack sits with flat feet on a carousel which is typically out of the range of the microwave OR has been built to reflect the waves in a manner that they will not damage the magnatron. Typically, a rack will be made of very small round stock that will not reflect much in any single direction ... besides that, you would have food on the rack that would absorbe most of the energy anyway.
If you replace this oven, please ensure you review all the warnings and instructions that will accompaly your new oven ... even the seemingly silly stuff like "dont use the microwave in your bath tub to heat the water".
I believe your oven is cooked. I'm sorry you are having this trouble and I hope my comments have helped you to arrive at a workable solution to your problem.
Thank you for your interest in FixYa.com
If you are pleased, the courtesy of a positive vote and response will be appreciated by this volunteer effort on my part.
Oct 03, 2010 | Sharp R-7A85 Microwave Oven
Whirlpool timemaster microwave removal
What caused the plastic metal rack holders to burn against the metal rack
Apr 06, 2009 | Whirlpool MH7140XF Microwave Oven
There are burn maks on the interior plastic. Is this harmful to humans?
It should not be harmful. does your microwave have the metal rack in it? if it does it should be taken out unless cooking 2 plates of food.but if it is from what i think it is then no its not harmful to you at all.
Nov 26, 2008 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
154 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
