Konica Minolta bizhub C351 All-In-One Laser Printer Logo
Posted on Mar 04, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Imaging units for my bizhub c351. Can I program the machine blck
I want to program my machine so I can use it. I am a few weeks away from having the money for the 3 color imaging units it requires.
Anonymous
Level 3:
Genius:
  • Master 2,120 Answers
  • Posted on Mar 05, 2009
Anonymous
Master
Level 3:
Genius:
Answers
2120
Questions
0
Helped
670113
Points
5011
Not possible on a Konica-Minolta
  • Anonymous Jul 27, 2011
    who are you..so full of ****..do not answer fi you do not know the correct answer! You can and there are several ways to go about that. The cheapest easiest is to change endlife to continue.
What does the p14 error message mean on a develop 550
DO you mean C550 Copier/Printer? P-14 means
problems with the following
1. PH relay board (REYB/PH)
2. Printer control board (PRCB)
3. PH unit
4. Imaging unit
Recommend you get a tech out to look at this problems
Print head (PH) contains the LASER. Printer Control Board $$$$$$$$$$$$$$$. PH/ REYB?PH board ALSO $$$$$$$$$. Again have tech come out look at this machine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Where do i find the imaging unit on the konica minolta bizhub c351
They are under the toners. I think you use the t handle tool to remove them. be careful of the toner port flap. they break easily.
Dirty mark appering at across top edge of paper on both sides on bizhub 351
if marks are repeating themselves (same each time) it is your imaging unit
if marks are random sorry to say it is your imaging unit
However if it is a continuous line or shadow you might have an obstruction in the laser light path
best to insert new new unit and go from there. You can always exchange back to the old unit
3helpful
How do I fix error code C2255 on my Konica Minolta C351 bizhub??
C2255 is the code for Color Developer Unit motor's failure to turn. This is usually caused by at least one of the Color Imaging Unit's being locked up or very hard to turn. If you are trying to fix this yourself then I would pull the Imaging Units out one at a time and check them against each other to see if one turns harder than the others. Note that there are 2 things to turn on the Imaging Unit. The Drum and the Developer section.
Good Luck and Thank You for using Fixya.
WheatlandServices
2answers
Machine status P-9 what is this message?
Black Imaging Unit failure
• All density readings taken from the density pattern produced
on the Transfer Belt are 0.5 g/m2 (IDC Sensor
photoreceiver output) or less during max. density
adjustment (Vg/Vdc adjustment).
on the Transfer Belt are 4.5 g/m2 (IDC Sensor
Photoreceiver output) or more during max. density
adjustment (Vg/Vdc adjustment.)
Remove and reset the Black Image Unit. If this doesn't help the Image Unit may need to be replaced.
Bizhub C351 Magenta Image Unit Problem
The C531 uses 4 toner cartridges and 4 corresponding imaging units. Each imaging unit has a waste compartment for the residue toner not transferred to the Image Transfer Belt (the waste bottle is for waste from this ITB). The residue toner could be reused.
It does not sound right that after 3-4K pages you have to change the IU. Just to be sure the IU you replaced looks like this?
ef6970d.jpg.
Each IU should last about 50K pages (ie to be replaced after 5 toner cartridges).
Error 2652
C2652 Magenta Imaging Unit EEPROM access erro. you need to:
1. check if EErpom of Magenta Unit is not dirty. if it is, clean it.
Else, replace the Unit image.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
