Question about Toshiba DKT-2020-SD telephone
How do I re-program the intercom button on a DKT3210_SD phone
I have a DK3210-SD Toshiba Phone. When I lift the receiver the intercom light illuminates and I have to push a line button to make a call. How can I re-program the phone so that an available line connects when I lift the receiver to make a call without having to push a line button.
  • 45 Answers
If you have the software you can select to pick up on line 1.
Or we can remote it and change it.
Tony
Posted on Apr 03, 2009
CHANGE THE DISPLAY NAME ON MY TOSHIBA DKT3210-SD PHONE
On a CiX or CTX, it's handled via the System Administration Program or Personal Programming Interface.
Sep 09, 2014 | Toshiba DKT3210SD - - Phone
TOSHIBA MODEL DK3210-SD we forwarded calls during lunch and now can not get them to disconnect..even using the codes provided
you probably could have a nite button on your telephone. Depending on the type of forwarding you set ( there are over 5 different types) you have to select the right one to turn it off. Go to http://www.telecom.toshiba.com/ and view the users guide
Aug 06, 2013 | Toshiba DKT-2020 Corded Phone
How do you get rid of the beeping noise when you dial on a Toshiba Business Phone - Model #DKT3210-SD?
Dial Pad and Button Beeps
Digital telephones can emit a “beep” sound whenever a dial pad or feature button is pressed. The “beeps” are On by default. Follow these steps to turn the “beeps” On or Off on 3000-series DKTs.
1. Press 3+6+9+Hold(simultaneously).
2. Press 0.
3. Press Feature Button 1 (FB1) to toggle On/Off.
FB1, LED On: buttons beep.
FB1, LED Off: buttons do not beep.
4. Press hold to set the option.
5. You must also go off-hook, then on-hook to exit the program mode.
Mar 03, 2010 | Toshiba DKT 3010 Corded Phone
NEED A USER MANUAL FOR A TOSHIBA DKT3210-SD CORDED PHONE
This is the direct link to the user manual on the web. The manual covers a variety of phone models including the DKT 3000 series phones.
http://www.telecom.toshiba.com/Telephone_Systems_Resources/User_Guides/pdf/Strata_CIXCTX_User_Guide_IPT2000_DKT3000.pdf
Feb 12, 2010 | Toshiba DKT2010SD Phone
I have a toshiba dkt2010-sd how go i program this phone ... right now my display screen has NO.11 in the upper right hand corner and lower left corner it has CALL 11-15
What do you want to program? to get rid of blinking light press intercom and dial #409 to program display name type Intercom #620 and #621
Jan 21, 2010 | Toshiba DKT2010SD Phone
DKT 3010 SD programming mode?
If the phone is on any Toshiba DK system, enter programming mode my pressing the following sequence (without selecting an intercom line, or an outside line, but at the phone's idle state with the handset down) *#*#1*2*3
On a CIX or CTX System, again, at the phone's idle state w/ handset down dial *#*#1*2*3*
Jan 07, 2010 | Toshiba DKT3020SD Corded Phone
Toshiba DKT2010-SD Phone
OK, model on bottom of phone is DKT2010-SD, but I found a little cheat card in a file for a STRATA DK8 & DK16 so I used a combination of things. First pick up handset and then hit intercom button, # 652 (for time or #651 for date) and enter time in HHMMSS (hour, minute, second) format, once complete hit the redial button.
Nov 03, 2008 | Toshiba DKT-2010 Corded Phone
RED INDICATOR LIGHTS FLASING ON INTERCOM
Thats a common "problem", but its easy to fix. The Intercom lights flashing like that is normal and they will continue to do so until you "assign" the phone its intercom number.  If you have more than one of these phones, go to your other phones, lift the handset and see what intercom number lights on that phone when you do so(the lights/buttons that are flashing). Notate which intercom number that is and move to the next phone. Once you have notated the other intercom numbers go back to the phone you wish to program and push PROGRAM , then push the touch tone key of which intercom number you wish to assign the phone (ie. 1 2 3, etc.), then push MEMORY.  That should do it, and if you need replacements their on Amazon. Good Luck
May 22, 2008 | Dual Handset Cordless Telephone with...
Toshiba DKT-2020-SD telephone Logo
327 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
