Question about Frigidaire FEF352 Electric Kitchen Range
Can not get oven door back on my Roper oven
The oven door hinges won´t stay open so that it does not grip the body of the stove
  • Frigidaire Master
  • 3,361 Answers
With the door on a flat surface.
Open (extend) the hinges and insert a small nail or pin in the holes in the sides of the hinges.
Then put the door on and remove the nail.
Posted on Mar 04, 2009
Oven door won't close all the way
I have had that trouble a couple of times. This might work. The door is usually attached to the body by two hinges with arms. You can lift the door off those arms and hinges by opening the door a few inches and lifting the whole door up in the air. Try this GENTLY. If the door acts like it will come off the body, it might be misaligned. Try lifting the door, and putting it back a few times, sort of gently twisting it from side to side. Really be gentle. This has worked for me several times. Be blessed.
May 12, 2013 | Ovens
One side of oven door hinge won't fit back in when putting door back on after cleaning
when you insert the hinges back into place flip the small lock tab at the hinge pin the locks the hinge for removal
Oct 19, 2017 | Indesit KP9508EXG Dual Fuel (Electric and...
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
My roper oven door fell off. We have tried locking the spring loaded hinges in place but they don't stay long enough to fit them into the grooves.
I put something behind the hinges, usually screwdriver handles, to hold them open long enough to slide the door onto the hinges. If you have the style that has the hinge on the door, you usually have to stick a nail into a hole in the hinge (in the open position), that is designed to hold it in the open position. Install the door, and remove the nail. Good Luck, Appliance Specialists
Jan 18, 2010 | Ovens
Dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
May 23, 2009 | GE Ovens
Reinstalling oven door
be exstreamly careful do not put your fingers near the hinge. somehow pull the hinge apart till the stay open and you may see a hole in it, put somethjing like a nail into it to prevent it from snapping closed. then put it into the slots on the oven till they are in the right position then open the door all the way and then just pull out the nails. That is if it is that type of hinge.
Oct 30, 2008 | Roper FEP320 Electric Kitchen Range
Stove handle/door
need strong fingers and a helper... lay the door on the floor push open the hinges and there is a hole on the side of the hinge have your helper slide in a small nail only about 1/4 " in to the hole this will keep the hinge out do the same on the other side then reinstall the door open up and remove your nails
Feb 26, 2008 | Whirlpool RF315 Dual Fuel (Electric and...
MAYTAG (AMANA) OVEN DOOR
I finally got my door back on, I had to wedge a butter knife in the hinge to keep it open, then I could put it back on the pins and slide the metal cover/locking thinge over it. Was a pain in the ass.
DANGdoor
Nov 27, 2007 | Maytag MER5755QAS CleanDesign Electric...
Frigidaire FEF352 Electric Kitchen Range Logo
253 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
