I was given eurovox max v and was asked to input new code this i did i am with ntl i put in the correct code and made sure the key and provider was correct after storing the new info and following the instructions and exited i was expecting the channels to be ok but on wxiting all i keep bgetting is chanel not available i also notice that there are four os on the front panel and they wont change values by either pressing the + or - on the remote control can you help
    Brigadier General:
  • 8,619 Answers
Hi!
You need to update the firmware of eurovox max v by reflashing it.
Before reflashing that try to use it with another tv.
Posted on Mar 04, 2009
  • Rylee Smith
    Rylee Smith Mar 04, 2009
    Make sure you connect the scart lead and not the coax one because it resets the box and you have to select rf in the config. Go to power scan get your right symbol rate for your area and then upload, channels should come up
  • 19,396 Answers
To start ensure that the codes are the latest ones , otherwise they wont work.
Give a call back to the provider to ensure that you have new codes.
I can search for latest codes on the internet, but as codes are used often to hack the provider, the information is often wrong.
  • Ginko
    Ginko Mar 04, 2009
    After ensuring that the codes are correct, try doing a power scan, I post instructions below.
    A power scan can take up to 30 minutes, then do not turn off the device during power scan:
    PLEASE NOTE : IF YOU ARE USING A SPLITTER IN YOUR SETUP THIS MUST B E
    REMOVED for the initial POWERSCAN as the box needs to scan from a pure
    signal- this will ensure all channels being found. – scanning throught
    a splitter can result in the loss of 50+ channels.
    Firstly before you start to scan the box you need to:-
    PRESS MENU
    GO TO CONFIG
    GO TO CLEAR DATA – IF IT ASKSYOU FOR THE PIN PRESS 0000
    SELECT – ERASE ALL CHANNELS
    Then it will ask you are you sure so press OK
    Then wait a few seconds then press EXIT and EXIT again
    What you need to do now is a POWERSCAN.
    The following is a step by sep method of carrying it out!
    Press the MENU button
    Go to INSTALLATION and arrow right to USER INSTALLATION
    Type in your pin (normally 0000)
    Press the YELLOW button for POWERSCAN and change the mode to FULL from Normal by arrowing right to reveal FULL
    Now press OK, this will begin the BRUTEFORCE POWERSCAN which can take
    up to 40 minutes,but it is guaranteed to find every single channel on
    the network in your area.
    Once done the box will switch to a random channel to indicate it has finished !
    You will now have around 240 or more channels (in some cases regions can receive up to 330 channels!)
    You now need to switch to a non free channel and let the box update the
    codes – this could take a minute or two, it will indicate on the screen
    “updating please wait” once finished all channels will now be unlocked.
    That’s it you’re all done … HOWEVER …. If you find that you get no
    channels at all there is a further adjustment you can make to ensure
    you get the 250 plus channels that your area box will be able to
    receive and again it’s quite simple to do!
    First press MENU
    Then go to USER INSTALLATION
    Type in your pin (0000)
    Press YELLOW button to POWERSCAN
    Then change the mode to NORMAL
    Then arrow down to the SYMBOL RATE and if its on 6.952 then change it to 6.887 (or vice versa!!)
    Then press OK and it will carry out a scan like the powerscan
    procedure from:setting up eurovox max
Anyone have the current eurovox max codes for ntl 5401
54 01 - STARVIEW 2 / 3 NTL BOXES
Key 01 = 5C 2C 26 36 CF 81 AB 66
00 code stay the same,
Feb 18, 2009 | StarTech.com StarView SV211K 2-port KVM...
Hi i need a code for the euovox max. im in dublin
5a 01
00 aa b7 d1 d9 ce 8e 83 af
01 a3 eb ec 07 d6 49 d2 eb
Jan 11, 2009 | StarTech.com StarView SV211K 2-port KVM...
Eurovox codes Jan 09
cw 5co1
key0= 7D 9B 0E 8B 69 3F E7 34
key1= 7D 9B 0E 8B 69 3F E7 34
Fixya!
Chris (ziraffa)
ps To put keys in manually do as follows.
Press menu button
Press 1570 this takes you into secret menu.
Now hit ok on nagravision
Next make sure your cable provider is listed at top NTL or TELEWEST C&W ect
Now change key 00
(YOU MUST SAVE EACH KEY INDIVIDUALLY - I.E. AFTER CHANGING KEY 00 MAKE SURE
YOU STORE BEFORE CHANGING KEY 01 (TO STORE PRESS OK)
Jan 09, 2009 | StarTech.com StarView SV211K 2-port KVM...
Ntl dublin (5401) eurovox max v codes
STARVIEW STBs
Press menu button
Now change key 00
If you enter your postcode into the following site it will tell you which area you are in and thus which keys you need to use (For NTL use Pure Keys):
http://www.dslzoneuk.net/ntl_region.php
THESE ARE THE FOLLOWING KEYS FOR YOUR PROVIDER AS BOXES ARE NOT AUTO ROLLING:
If you got problems, then, if the box is genuine, try reflashing the box with the latest software, factory reset, scan..
If the box is a clone do the same as above but with clonesafe firmware.
This might be a good link for you to bookmark.
Also here for the latest fixes.
Chris (ziraffa)
Dec 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
EUROVOX MAX V - North East /Mbro
ok try this to sory your problem out. Press menu, 1570 , on nagravision screen is EMU set to ON ?
press ok , code screen make sure this is in box . Provider ID NTL 5401,
key 0. 3F B8 36 62 72 E5 E2 76
key 1. 35 5E D6 40 6E AA 99 41
should work fine now .good luck.
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
Codes for eurovox max telewest/virgin bradord area
go to http://thechatterbox.cc and download the Chatterbox toolbar. Then Downloada program called KeyMaster on there.
For EUROVOX
Press MENU then press the Yellow button
For STARVIEW
Pres MENU then press 1570, go to Nagravision, Either enter provider number (look below) or Select your operator.
Now go to 00, Input Code into "DATA", press OK, Now go back up to 00 and press Right button, to change it to 01, Enter the 01 code in.
Provider ID is as follows,
Before Virgin Media took over, type in what ever code is next to your old supplier..
NTL - 5401
TELEWEST - 5a01
C&W - 5c01
When you find your codes of the Keymaster, you should have Key 00 and 01,
On your screen go to 00 and type the code you got of the internet,
Now do the same for 01,
The codes will change every day until new software is released.
Use the key on the bottom of your screen to type in the Letters.
Keys as of 29/11/2008 (Might have changed by the time you read this)
NTL - 00: CD 11 58 05 EE 96 E7 F3 // 01: EA B7 BF B2 D5 AA 46 AB
C&W - 00: 00 58 8D CF 27 98 04 ED // 01: 2A E0 72 B0 9E 07 9B 5D
TW - 00: 98 B0 BA 52 D3 21 08 B4 // 01: D2 EA 29 B7 B5 52 E9 AD
Nov 29, 2008 | Audio Players & Recorders
Eurovox max v ntl codes
00= 31 6F CB 3F 2E 45 5A 04.
01= 80 AD D1 D3 80 90 FF 2B
Nov 27, 2008 | StarTech.com StarView SV211K 2-port KVM...
Ntl code for eurovox max
For EUROVOX
For STARVIEW
NTL - 5401
TELEWEST - 5a01
C&W - 5c01
Oct 25, 2008 | StarTech.com StarView SV211K 2-port KVM...
Televison & Video Logo
Top Televison & Video Experts
