Question about HP JBL Platinum Computer Speakers
They worked yesterday i unhooked them to try different speakers, the different ones failed to work when i rehooked jbl they no longer work, no power getting to them at all cant even turn them on
  • thewizman23
    thewizman23 May 11, 2010
    Hello, my name is Chris. I would suggest making sure the power cable is plugged in. Or that you might have blown a braker in your house. I would need more information.
  • 66 Answers
Yeah, try plugging it into another outlet...ports on power strips and outlets go out.
Posted on Mar 12, 2009
How do I get speaker to work with Samsung S5 with good sound quality
Be sure JBL is charged, press the power button on JBL, press the Bluetooth button on JBL. Turn on your phones bluetooth,make it visible to all devices, make it search for aplliances. When it finds JBL - pair it (you may have to make up a pairin number). The "sun" button controls different sound qualities. And turn the volume up! You should download the JBL MUSIC FLOW APP from the APP STORE to make the most of it.
Feb 19, 2015 | JBL Pulse Portable Bluetooth Speaker
JBL BP600.1 protection
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Using an ohm meter to the sub will confirm whether its bad or not. Invest in a cheap test set of 6.5" speakers.
.A thumbs up would be greatly appreciated if this answer is helpful to you.
Jun 02, 2013 | JBL BP600.1 Car Audio Amplifier
I have the JBL speakers which are really decent but i want them to be as loud as possible! if i plugged in my logitech speakers into one of the inputs that i would normally put one of my little speakers in...
It should be OK BUT if the JBL and the Logitech are plugged into different mains outlets you could get a hum from one or both sets of speakers. This hum is caused by an earth loop when the speakers are connect to different mains outlets.
The fix.
Connect a power board to a mains outlet and then plug the mains connections from both set of speakers and computer to this power board.
Oct 25, 2012 | JBL Encounter 2.1 Computer Speakers
Driver jbl pro speakers
I use these speakers since 2000. It will be 9 years this October!!! They work very good. I never used any drivers for them. I changed three computers with different mother boards / sound cards and they worked fine with any Sound Manager I tried.
Jun 27, 2009 | HP Compaq JBL Pro (401508-001) Computer...
No sound out of JBL LSR25P speakers attached to keyboard
problem could be in wiring, fuse, crossover or the components can be damaged. the original JBL tweeter and 5.25" speaker are no longer available so replacement options would be the only alternative.
cathy@speakerex.com
Jun 13, 2009 | JBL LSR25P Speaker
No low end on JBL EON G2
please use a different connectors and try if it works
Dec 15, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL EON15-G2--Does the HF Amplifer to the driver have any voltage?
The 2 leads that come off the HF driver are different sizes...you should only be able to hook them up one way. Takes the guess work out of it for ya.
Assuming there is nothing wrong with the speaker, hooking up the 2418H HF driver to it should do the trick. However, I blew my HF driver a few months ago and bought a new one, only to blow it immediately. This was because the motherboard of the JBL EON G2 had actually failed and caused the HF driver to fail. Once I replaced the motherboard and the HF driver (again) everything was back to sounding great. Hope that helps.
Oct 10, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL On Tour no longer work
i tried it but it still wont work!! PLEASE HELP
Aug 13, 2008 | JBL (JBLONTOUR) Computer Speakers
Jbl psw1000 no power
Have you checked all fuses. There might be 2 - one for the input and one specifically for the amp section...
Check to see if the speaker is fried. Remove the grill then place your fingers as evenly as you can aa couple of inches away from the cone. Press gently and listen. There should be no scrating sounds at all. If you hear this, first try repositioning your fingers. If it persists your speaker is fried. This is caused by a few reasons. Amp failed and took speaker with it. Or a large signal was inputted which causes the amp to hold its max power for a longer period of time (amplified signal is no longer a sine wave but a sqare wave).
Otherwise, unless you know what you are doing with AC (house power) I don't suggest you go poking around-you need at least a volt meter to start testing
Dec 21, 2007 | JBL PSW1000 Speaker
HP JBL Platinum Computer Speakers Logo
70 people viewed this question
Top HP Audio Players & Recorders Experts
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
