Question about Maytag Neptune MCE8000AY Electric Dryer
Maytag dryer model HYE3657AYW
I brought a dryer from USA to Mexico, my dad does not want to install it because he is not sure about the kind of electricity is in Mexico there are two kinds of electricity, 120 and 220, somebody can to tell me what type is?
Maytag dryer hye3657ayw will not run. There is power at the outlet but the light does not come on when the door is opened.
Posted on Jul 07, 2011
I assume that your u.s. dryer is the standard 220 volt, and your question is what is the voltage in Mexico where your father resides. Most places in Mexico will have the 220 volt supply available. This should be easily found out with any cheap 15.00 meter. If the receptacle accepts the dryers plug, it is more than likely the proper voltage.
( Maybe your father is really wanting to save energy and realizes that his clothes will last forever when they are hung up to dry! )
Posted on Mar 05, 2009
Maytag dryer hye3657ayw does not run. When I open the door the light doesn't come on but there is power at the outlet.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 07, 2011 | Maytag Dryers
My dryer stopped running in mid cycle and there was a burning smell. I thought it may be the belt, but it is not the belt. Also, the light inside the dryer hasn't worked for years, so I don't think...
heatman101
Jun 15, 2011 | Maytag HYE3658AY Electric Dryer
Magtag HYE3657AYW. I have reaplace the thermal regulator and the fuse. What could it be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 03, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Need routing for dryer belt on Maytag Dryer Model HYE3657AYW
Hi michaelpalma...
Go to this website for a picture of how to route your belt.
Free Answer...Please rate Me
http://www.applianceaid.com/images/belt-config.JPG
Apr 20, 2011 | Maytag Dryers
Have a Maytag electric dryer, model # HYE3657AYW, stopped working all of the sudden. doesn't do anything when I set the timer and push to activate. I checked the voltage at the plug, and at the back of the...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 07, 2010 | Maytag Dryers
Heating element out, dryers runs
replace element but clothes still wont dry helpppppppppppppppp
Apr 21, 2010 | Maytag HYE3657A Electric Dryer
I have a Maytag Dryer Model No HYE3657AYW and it will not start at all. The inside light does not even come on. I checked the circuit breaker and no luck there either. Any suggestions?
a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Dec 13, 2009 | Maytag HYE3657A Electric Dryer
I have a maytag model HYE3657Ayw how can I open it up to clean lint inside the cabinet
first pull it away from the wall, then clean out the lint from the vent, then you will need to pull the front panel off, you should find 2 screws inside the door opening, and then you will need to pop loose the tabs from the bottom
Jul 10, 2009 | Maytag Neptune MCE8000AY Electric Dryer
How do I get inside the machine to change the belt? Thanks
most older models you can pop the lid and there should be screws on the inside holding the front
May 01, 2009 | Dryers
Maytag dryer
Your door switch might be defective and/or your timer might be defective. If it has a fuse inside it might be blown.
Oct 07, 2007 | Dryers
Maytag Neptune MCE8000AY Electric Dryer Logo
435 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
