Question about D-Link DSL-2320B
D-link dsl 320b lan light
Hello
I had a quite bad problem since these days and I would like to get your help! I have a d-link 320b modem and it is working with Ethernet cable......I have installed all the drivers and plugged all the cords carefully but when I turn on the modem's power the LAN light doesn't turn on. But when I plugged the Ethernet cord to another computer it worked fine. My modem is installed from the d-link site a there is no problem but in my own computer the power goes on and even the status and dsl but the LAN doesn't turn on and the computer doesn't connect to the internet!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 27 Answers
Maybe it is ethernet driver
Posted on Apr 23, 2017
5 Suggested Answers
SOURCE: Problem with my d-link dsl-2320b modem
try resetting the browser try to change the micro filter turn off the modem and computer power it back and check try connecting the modem to the main telephone socket check if the if ur phone line works fine after all these check the problem still continues its dsl connection problem
Posted on Nov 03, 2008
beeveez
  • 167 Answers
SOURCE: D-link Modem Lan Light
Try to update the firmware of your modem.
Posted on Mar 09, 2009
SOURCE: D-LINK DSL 302 G modem connectvity problem
D Link doesn't seem to have drivers for download for 302g and Windows 7
Posted on Feb 13, 2010
Rider On Way
  • 1679 Answers
SOURCE: Actually involves a D-Link DSL 300G Modem. Loses
This is common issue with the D-Link modems. There is a firmware update released by D-link.
Download the firmware update and install. It should fix the issue.
Download Firmware
Let us know if it fixed the problem
* Please rate this solution and comment on it
Posted on Nov 12, 2010
I recentley bought a dsl 2320b modem and now found out that it isn't supported with dlink anymore. There is no internet light on and the status light flashes very little. power light is red. dsl is steady...
Do you have an Internet service provider (ISP), like AT&T or Verizon (if you live in the US) ? Usually, your ISP will give you a modem/router (cable or DSL) for free when you sign up with them for Internet service.
Dec 20, 2014 | D-Link DSL-2320B
Theres no dsl light on the router, its a d link dsl2640b. so i need to know if its broke, the power light is on and the status light but no dsl light and no internet light on router, the pc is showing...
The flashing DSL light means that the modem isn't seeing the DSL signal on the phone line it's connected to. This might be due to modem failure, but it might also indicate a phone line problem. The most common trouble I run across is an unfiltered device connected on the line that interferes with the DSL signal. Other than the modem, all devices (phones, fax machines, security systems, etc.) need to be connected to the line through a filter. Check to be sure something hasn't been connected without a filter. Sometimes a phone gets moved or a new phone is added that gets plugged in to a handy jack without being filtered.
If you can, try connecting another modem to the line. You may be able to borrow one, or find one at a resale shop. I see them quite often for only a couple of dollars, leftover from people changing to FiOS or cable service. This can help determine if the modem is responsible.
One final possibility: your DSL service has been cut off. I've had two cases where loss of DSL was a phone company issue that they needed to fix at their office. (One following some wiring work done in apartment building, the other when service was mistakenly disconnected from the wrong customer.)
This kind of trouble can be a headache to solve, but it can be solved. Good luck and thanks for using Fixya!
May 21, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Hello, the 4 LAN ports on my D-Link router, model DIR-615, don't seem to be working. The lights are not coming on. This is the 1st time I'm trying to use those LAN ports so that I can connect my new...
It probably is your router that is the problem.
Disconnect its AC power, and reconnect it, to "reset" the router.
Also, try connecting your Blu-Ray player directly to your cable-modem (or DSL-modem), bypassing your router. Turn the modem off, and then turn on, and then turn your Blu-Ray player on, and it should be able to connect to the Internet (and NetFlix).
Try a different router.
Oct 17, 2010 | D-Link AirPlus DI-524 Wireless Router
Unable to connect to internet. Only two lights show -- power & dsl. When I called for help I was told I needed a new ethernet cable. Bought that & installed. Same problem -- only two light lit...
In all there should be lan led, dsl led, power led and internet led,
So if dsl and power led is glowing and others not?? than check the lan cable and even check the lan card of ur pc is it enabled or drivers are properly installed and same way try to check the modem configuration??
Sep 08, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Ethernet light flashing
Check your DSL Filters on your house phones or anything connected to the phone line EXCEPT the modem. The modem should not have a filter on it. If this doesnt help I would recommend getting your ISP out to test the line because sometimes the resisitors or hardware in the box goes bad or at the DSLAM.
Jul 20, 2009 | Efficient Networks SpeedStream 5667 Modem
Mar 04, 2009 | D-Link DIR-625 (790069292637) Wireless...
Nov 03, 2008 | D-Link DSL-2320B
Wireless router
Yes, you can use wireless router with the modem. I guess the actiontech DSl router that you have is also Wireless one. If so, you can use just the DSL router for wireless connection. If you really want to use Dlink router with it, Connect the ( WAN port ) of the Dlink router to the ( LAN Port ) of the Action tech modem [ modem(LAN)-->Dlink(WAN) ]. Once you do this connection, better to do power cycle ( unplug the pwr to the dlink first, then, disconnect the pwr to action tech - wait 1min and plug the pwr to modem, wait for DSL light to be solid , then put the pwr back to dlink ). Make sure DSL light on the modem solid, internet light & WLAN light on the link glowing.
- Make Hardwire connection between the computer to Dlink and check the ip address on the computer whether it acquires the ip address from Dlink and then check the internet connection on the computer, it has to work. if computer not getting ip from dlink, try restarting computer.
- If hardwire connection on the dlink works fine and check the wireless connection.
For wireless configuration or assistance you may check this link:
http://www.portforward.com/help/wirelessxp.htm
please feel free to ask, if you have any more assistance.
- Laxman
Nov 22, 2007 | Actiontec (GS204AD9-02) Router...
Open Questions:
D-Link DSL-2320B Logo
289 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
