Question about Maytag MMV6178 Convection Microwave Oven
Maytag MMV6178aaq microwave display not working.
After removal of PCB, noted black spot on upper right corner of display part. Controller appears to work correctly; however, the display is black.
  • kc66062 Mar 07, 2009
    To verify the connections were attached correctly. All the buttons work, but the display remains black. There is not visual indication to buttons pressed, only audio beeps.
  • William Miller
    William Miller May 11, 2010
    Why did you remove the PCB?
    The black spot in a vacuum fluorescent display tube is supposed to be there. It is a spot formed after the tube is evacuated.
    We
    regularly repair such control units for customers nationwide by mail
    for $39.95 postpaid in about a week with a one-year guarantee.
  • Maytag Master
  • 9,086 Answers
Well, assuming your connections are good on the board, and you;re getting about 3VAC on the filament leads (outermost two pins), I'd say you would need a new board assembly.
(The VFD tube is not available separately).
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Posted on Mar 10, 2009
The display on our Sharp Microwave oven went very dim. Everything else on it is still functioning perfectly. Will replacing part FPNLCB666WRKZ fix it? Is this something we can safely do ourselves?
not familiar with that exact model .if the display went gradually dim and has a green vacuum florescent display ,these suffer 3 problems ,worn out display ;glass on display and filter window dirty ;and failed capacitors,suggest before replacing module ,unplug and put plug iside door ,then safely remove the back then take photo of display panel wireing then remove it clean inside the plastic eindow of display and display tube glass window .visual look at pcb you will see several round blue capacitors .note the values and voltage of these i.e 470u/25v. go to maplin and obtain replacements ,yhen get a friend who can solder to replace them all making sure to mark pcb with black marker ajacent black negative line on capacitors to ensure correct polarity then refit pannel and test .if no improcement replace complete panell
Dec 28, 2015 | Sharp R-314FS Microwave Oven
The unit started arching inside the front panel on the upper left corner.
Arcing Inside the Microwave - Martin Microwave Inc.
microwaveglasstrays.com/shop/articles-arcing.html
Microwave Glass Trays, : Arcing Inside the Microwave - Microwave Glass Trays ...glass tray, microwave plate, glass trays, turntable, microwave oven, carousel, ...microwave energy, and will eventually it will start producing arcs and put out one heck... the damage is non-repairable and the unit should no longer be operated.
Notes on the Troubleshooting and Repair of Microwave Ovens
www.repairfaq.org/REPAIR/F_micfaq3.html
Microwave oven does not respond to START button. First ..... but with the leakage from the spot welded waveguide inside the unit. ... My clue in was a spark between the waveguide and the case, when I was messing with the Controller PCB.) ...
MICROWAVE OVEN ARCING ' MICROWAVE OVENS
Dec 15, 2015 | Microwave Ovens
My GE microwave has a Keypad short. Do I have to replace the entire control panel?
Depending on part availability I would recommend the replacement of the keypad "membrane often shorts" but they may offer the control board with it since it ties together.
Mar 14, 2012 | GE Microwave Ovens
GE microwave/convection oven 1790 there is a #8 displayed in the right upper corner of display
HELLO.
When the F8 code appears,it means that electric control requires replacement because the relay drive circuit has been lost.
Attempt to clear the code by pressing Cancel and cutting power to the range for 30 seconds.
If the code cannot be cleared, replace the electric control.
thanks.
Sep 21, 2011 | GE JVM1790SK Convection/Microwave Oven
Unit 3.5 years old and now is not heating up and noted a small logo to the left hand lower corner of the display area...does this mean anything? Stacy
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 12, 2010 | Maytag MMV4205 Microwave Oven
Removal of front glass panel
The glass is not removable, due to safety reasons when the unit is being used.
Feb 07, 2010 | Maytag MMV5165 Microwave Oven
Bottons on microwave do not work
HI, the touch pad board has failed. you will need to replace this damaged board asap. this will correct the issue.
Sep 27, 2009 | Microwave Ovens
Emerson MW8997B desktop microwave beeping
Hi, probably something happened with the PCB due to an abnormal current fluctuation.
You should go to a service center.
Nov 13, 2017 | Emerson Microwave Ovens
Microwave not heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
jkjf
Apr 02, 2009 | Maytag MMV5207BAW Microwave Oven
Maytag MMV6178 Convection Microwave Oven Logo
466 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
