Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Inside fan not running in heat mode
Inside fan will not run in heat mode model msh09tw mr slim
  • 4 Answers
I belive these units may have a cold air prevention sensor in them which wont allow fan ops until the coil reaches temp
Posted on Mar 05, 2009
Icing up outside. no heat inside
Isolate unit to defrost out door unit,
Once defrosted run unit ensuring heat from unit inside and fans are running outside,
if fans and compressor are running and there is next to no heat inside coming from indoor unit this is a common sign of a refrigerant shortage in system and this may cause outdoor unit to freeze up
Jan 24, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Heat Pump Cycling too frequently?
It should run until it reaches the temp. setting on the thermostat.
Do you have a make and model number so I can assist you?
Jan 11, 2014 | Mitsubishi MSH09TW Air Conditioner
Mr slim ticking noise
Open it and take a look, it could be debris or a loose wire.
Dec 06, 2013 | Mitsubishi Heating & Cooling
Operating indicator light is flashing on Mr.Slim A/C
I had the same problem and I found it was that another unit had the heat running while I was trying to run AC on another (they're both attached to the same condenser) so it could only run heat or AC not both. Turn off the heat!
Mar 25, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
Fan won't work on heat mode
the fan has a circuit that faults with error E6 because the circuit is looking for outside condensor unit. I would like to run the fan as a stand alone.
Dec 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi - I have a MR SLIM MSZ A09NA HEAT PUMP. It is dripping inside the room. It was installed in 2008. Is seams to be loose on the wall. Is it supposed to be level? tipped to the right ?
An air conditioner should be installed so it's level. These appliances are designed so that condensate collects below the fan and runs into the slinger ring, which is made of sheetmetal and is part of the fan assembly. The bottom of the ring acts like a gutter to collect condensate. The fan then picks the water out of the ring and slings it against the condenser coils.
Recycling the condensate in this manner increases the coils' cooling capacity. Check the air conditioner for level -- front to back and side to side -- when you install the unit.
If it is tipped a little to the Front then you will Get water inside room.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have 2 Mitsubishi electric "Mr Slim" type
Have your system checked by a professional.
From what you are describing here it seems as thoug you have a slight leak in the system somewhere and therefore the system is not cooling or heating properly.
Have them check the system... verify the low charge, fine the leak and repair it.
Vacuum and recharge the system...
Then check the operation before you let them out of your sight.
...It can be tough to get some contrators back if you let them go before you check it...espec. if you pay them...:-)
Nov 19, 2010 | Mitsubishi Heating & Cooling
Fan is always running, is this normal operation procedure?
check on t-stat ad see if the fan is on or auto with fan on the fan will run all the time with fan on auto it only runs with a call for cooling or heating .
Nov 16, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
373 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
