Question about Dell Dimension C521 PC Desktop
The port lan 10/100 integrated RJ 45 don't work
  • kanyb Mar 07, 2009
    HI!
    Thank you vey much, i try all solutions but no way
    Now, i'll try to buya new ethernet card compatible with my dell dimension C521.
    This is an other probeme because i don't know how and there to put it in the desktop.
    RGDS
    Hippolyte
    Sergeant:
  • 271 Answers
Try with another cable.
This happened to me once- just replaced the cable and it worked.
Posted on Aug 04, 2010
    Scholar:
  • 73 Answers
Have you tried to reinstall your Network drivers?
Get them here.
If that doesn't work and the port is bad (it happens)
buy a new pci network card and install in the machine, fairly inexpensive solution.
Please let us know if this resolves your issue.
Thank you.
Posted on Mar 04, 2009
Sb5120
1.screw the cable line into the (F-connector)port in the back of the modem just like a tv does.2.then use the RJ-45 lan cable supplied with the modem,plug it into the RJ-45 port in the back of the modem.3.then plug the other end of the cable into the computers RJ-45 port.4.then power on the modem by pluging it in,and letting it boot and detect the internet signal and all lights are on and in working order.then start surfing.The only time you will need the install cd is if you need to use the usb hook up on the modem.
Jan 31, 2012 | Arris SURFboard SB5120 Modem
Tip
Using Zyxel P-600 from two PCs
to use Zyxel router/modem from two pcs for internet usage : it has two ports 1 is USB 2nd is Rj-45 connector LAN port
connect it with one pc via USB cable and connect 2nd via LAN port using Cross cable then its one DSL connection from two PCs.
i am using it and it working good.
on Apr 20, 2010 | Computers & Internet
Processor: Intel Pentium D - 3.4GHz processor (Dual-Core) Memory: 2048MB RAM Hard Drive: 400GB Optical Drive: CDRW/DVD Rom drive (combo) Operating System: Microsoft Windows XP Professional SP3...
You have to have some sort of a modem to get online whether your using a smartphone through a usb or broadband modem through your rj-45 jack, Broadband modems also have the capability of using a usb cable to connect to the modem. Hope this helps. Not sure exactly what your asking. If I havent answered your question feel free to let me know!!!
Jun 13, 2011 | Dell OPTIPLEX 745 PC Desktop
I can't reset the DSR8035 to factory default values. I am connecting using a null modem cable through COM port 1 on my laptop. The HyperTerm settings I am using are 9600 8-N-1. I don't get a...
ehm the 8035 doesn't have a comp port but an RJ 45 port, the unit comes with a rollover cable and an Avocent Adaptor which should be used to access the unit.
The parts are the following items:
540-604-501 Adapter [RJ-45 to DB-9 DCE Female]; equivalent to Equinox 210095
540-605-501
Cable [RJ-45 Reversing Modular Cable]; equivalent to Equinox 690226
May 11, 2011 | Avocent DSR 8035 (DSR8035001) 32-port KVM...
I have a cable modem that doesn't want to accept the RJ-45 cable (I think that's what it is called.) I've tried several different quality cables with no luck. Strange problem. Any tips?
Some RJ 45 jack cable has fault so try with another RJ 45 jack cable .. Purchase new rj 45 jack cable from nearest computer shop. There must be 2 port on modem 1 for ADSL phone line cable and otthr for LAN ethernet port means RJ 45 jack port. Try with another rj 45 jack cable it should be connect.Make sure that LAN port of modem is not faulty means make sure pins on that port are not break. Let me know if you need further assistance. Thanks for using FixYa.
Jul 24, 2010 | Computers & Internet
Does my w3507 have an agp port
No it does not have an agp port. IT has a PCI Express Port for video cards. Its much better and faster.
Details on your machine and what it has can be found at this link. Hope it helps.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2912877&CatId=2643
Nov 10, 2009 | eMachines W3507 PC Desktop
Uplinking Using Gig Copper
hello, use the plugin modules for the rj 45 connection port to uplink it.
Aug 04, 2009 | Computers & Internet
Modem
Technical Specifications AAL and ATM Support
VCI 0-65535 address range
VPI 0-255 address range
AAL5 support
Bridging
IEEE 802.1.d Transparent Learning Bridge (dynamic learning of up to 255 addresses)
Spanning Tree support
Certifications
FCC Part 15, Class B
CE certification
Connectors
DSL interface: RJ-11 or RJ-45 (Europe)
Ethernet interface: RJ-45
USB Type B interface (5200, 5500 series)
Diagnostic LEDs
Power, DSL, Activity, Ethernet status; USB status (5200, 5500 series)
Management
Intuitive, Web-based GUI management access
SNMP support
Comprehensive hardware diagnostics
Media Interface
RJ-11 or RJ-45 (European) DSL WAN connection
10/100Base-T RJ-45 Ethernet LAN connection
USB Type B LAN connection (5200, 5500 series)
Power
12V power supply included, 700ma max. 5400/5500 - 12 VDC, 1000ma max.
Routing
DHCP server/DHCP client
Network Address Port Translation (NAPT)
Network Address Translation (NAT)
Packet filtering
RFC 2364 Point-to-Point Protocol over ATM PVCs (PPPoA)
RFC 2516 Point-to-Point Protocol over Ethernet (PPPoE)
RFC 2684 (formerly 1483) Bridged Ethernet and routed encapsulation Routing
Standards Compliance
IEEE 802.3
USB 1.1 T1.413 issue 2 G.992.1 (G.DMT) G.992.2 (G.Lite)
Oct 15, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Networking
Well, I would guess that if you are hooked up now, then you have a wireless router. If this is the case then you should have rj-45 (ethernet) ports on the back of it also for lan hook-up also. Must come with atleast 4 LAN ports, 1 WLAN port (for the incoming internet signal from your cable/dsl modem), so if you use a reg. ethernnet cord, then yes you should be fine hooking your ps3 to your network(via ethernet cable to your wireless router from the ps3).
Hope this helps...
Jul 18, 2008 | Sony Playstation 3 (PS3) Console
Dell Dimension C521 PC Desktop Logo
117 people viewed this question
Alun Cox
