Question about GE D52GW12 52" Rear Projection HDTV-Ready Television
GE D52GW12 52
My GE d52gw12 rear projection will not turn on the power light turns on for about 5 seconds there is a high pitched squeel and then a click and it turns off.
  • 544 Answers
it seems that you have problem in a power part of your machine.
please go for your service center as soon as possible to fix it.
i strongly advice you that please don't use it or try to open it for know until it is not open for preventing an additional problem.
thanks,
Posted on Mar 04, 2009
  • 10,594 Answers
Symptoms shows TV has some problem in Horizontal deflection section and most probably H-Out Transistor or Fly Back Transformer is fried.
If you are not familiar with big TV repair then call local TV tech for a look.
    Genius:
  • 1,550 Answers
The fuse is blown in your tv .
It causes the tv to go to protection mode.
  • GE Master
  • 19,396 Answers
That is an internal fault, either on power board, or on one of ballast boards powering up the lamp.
  • Ginko
    Ginko Mar 04, 2009
    The high pitched noise can be caused by a blown capacitor, either on power board, or on the small AC board that power up the lamp.
    To fix the problem the TV must be taken apart, and the faulty component replaced.
    Do not keep turning on the tv in this conditions , as you may cause more damage.
    If you want to call a technician you can use the phone number listed on the owner manual.
    If instead you are a technician and wants to fix it yourself, start testing the caps on power board, and reading voltages out from pwb. If you find nothing in there proceed in testing ballast board, and then convergence and dmd board.
ON our GE D52GW12 52" AFTER TURNING TV ON IT
Try resoldering the flyback transformers connections on the board. Its very common for the flyback pins to develope cracks around the pins which can cause that issue. I would check that first with that model.
Jun 13, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
My GE D52GW12 52 in TV only turns on after I push the power button numerous times (sometimes up to an hour). The green light on the power button comes on but kicks off after about 5-10 seconds. It is...
Thats a very easy repair which is almost always related to failed power capacitors CP150, CP120 and CP114. You can get the RCA repair kit which is the same as the GE from www.tvrepairworld.com the kit is called the ATC221 CP150, CP120 & CP114 repair kit . The kit contains the caps and the CD with instructions for the repair.
Apr 30, 2011 | GE D52GW12 52" Rear Projection HDTV-Ready...
High pitch noise, no picture. GE 52" projection, Model D52GW12
Ur high voltage FBT the flyback tranformer,a big black block of plastic with a gray wire connected to a board.The cap it dead.The FBT it useally it dead too,arching noise FBT not holding the high voltage.
Mar 30, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE TV will not trun-on
Deflection Board,Ck capacitors cp114,cp120,cp150 IF cp150 is puffed up on top it is bad also replace other 2 capacitors in same circuit they are cp150- 2200uf16v and (TWO) 220uf35v.You can order rebulit deflection board from UED -type in www.UED.com
Aug 06, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
My ge 52' hd rear projection tv wont turn on.
replace the flyback you can get a replacement at the following link leave a email with your model number and they will respond quickly with which flyback you need they also provide free instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/
Mar 14, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 turns off
I have the same problem, what the heck. it's over for it
Jun 09, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
GE D52GW12 52" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
