Question about Technics SA-AX910 Receiver
OVERLOAD ALL LONG TIME I SEE THE HIGH TEMPERATURE EXTREME ON FUNCTION MORE THEN 50% FROM LEVEL POWER VOLUME. I DECOVERY THAT THE MODEL SA-AX910 HAVE A FAN AND U NOT TO LISTEN THE FAN. I LIVE ON RIO DE JANEIRO E ENVIRONMENTE TEMPERATURE IS HIGHT. THE OUTPUT LEFT AND RIGHT INTERRUPT AND IMEDIATE SHOW ME IN DISPLAY THE MESSENGER "OVERLOAD - SHUTDOWN POWER OFF...". HELP ME PLEASE, THE PROBLEM IS INTEGRED POWER OUTPUT AMPLIER OR AC SUPLY POWER FROM SISTEM. THE FUSE OF THIS PROTECTION SISTEM ARE CORRECT FUNTION IN POSITIVE ON, BUT THE HIGHT TEMPERATURE BURNED THE INTERNAL TRANSFORMER OF SOURCE OF ENERGY AC. THE RECEIVER POWER ON, SHOW ME IN THE DISPLAY THE NORMAL PROCEDURAE AND SHUT DOWN IMEDIATE WITH THIS MENSSAGE AFTER 3 SECONDS. THANKS RICARDO REIS WWW.BRHUMANITAS.ORG
SOURCE: Technics SA-DX940
overload, usually means that is overloaded. i've had the receiver for about 4 or 5 years now and never had problems with it. It was sitting ontop on my tv for those 4 or 5 years, and i haver noticed it untill just recently, (when i bought a new tv and i had to get a stand for it, and i had to stick the receiver in it)that is runs very hot, very quickly; Maybe that is the problem you are having now, that the thins is older and maight be able to handle it as it id b4. Maybe you made some changes to your set up: new speakers, etc.
Posted on Sep 15, 2007
Ratnesh, I have this same receiver and the fan only comes on at certain volume levels. Unfortunately I now live in an apartment and can very rarely listen to it that loud. I had the same problem for a little while until I thought about moving the receiver to the lowest shelf with nothing on top of it. This seems to have worked so far although it does still get quite warm. Good luck!
Posted on Sep 28, 2007
SOURCE: technics sa-ex300 says overload ?
it could be overheating - try aiming a fan at it for a while, see if the problem stops.
Posted on Aug 05, 2008
SOURCE: I have a Technics SA-AX610 receiver that says overload .
From the manual pg 27....... "The protection circuitry has functioned because the positive and negative speaker connection wires are "shorted," speaker systems with an impedance less than the indicated rated impedance of this unit are used or under severe use, such as loud volume, excessive power and in an excessively hot environment."
Posted on Jan 17, 2009
SOURCE: Technics SA-G9057 overload
Check the fan connections at the back. The connections (just two flimsy metal prongs) came apart (I believe), so I have had to re-enforce them with electrical tape so the connections stay together until I investigate a further replacement fan. For now the connections are extremely sensitive to motion/viberation/impact/etc... but it does work now.
Posted on Apr 03, 2009
My Technics sa GX350 tuner keeps going into overload. It's the only thing plugged in.
Hi mate, had the same problem with my amp.. Take the top off and there is a fan at the back, there are 2 piece's of copper flat wire that touch together and these do not touch anymore so when its turned up or the bass gets stronger it cuts off as the fan should kick in at this point. If you can get these to touch again (bend them) then the problem will be gone!! I have had to do this a few times now though so this is not a long term fix.. I may try soldering!
Jan 01, 2011 | Technics SA-AX910 Receiver
Describe your I have a technics sa ax910 turning
1 You may have a failing power supply regulating circuit in you amplifier and the fail safe circuit is trying to protect the rest of the circuit.
2. there may be a voltage overload at the primary side of the power supply circuit which in this case is causing it to shut down.
Jan 06, 2010 | Technics Audio Players & Recorders
Technics SA-AX7 OVERLOAD problem
hello there are 2 big capacitor behind the metal heatsink see if one has swelled up if so change them both then check the output chip to see if there are any dry joints then when you've check all and still the same then you may have to change the output transistor g ood luck
shaun
Oct 01, 2009 | Technics SA-AX7
Overload displays on the screen
If it say's overload with no speakers connected and the unit on, it needs service. If you need further help, post a comment and I can help you troubleshoot.
Aug 11, 2009 | Panasonic SA-HE70 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
I need help
Loose connection on "POWER-SUPPLY" and sometimes solder loose on "C I S BOARD" due to extreme - heat of amplifier. $137.51 repair done in 1HR as I waited at CENTURY SOUND ELECTRONICS.
Jan 19, 2008 | Audio Players & Recorders
Overload
internal wickman fuses blown check speakers high unts tweeters\ gone short primary transistors /ic blown
Dec 31, 2007 | Technics SA-DX940
Technics SU-G91 OVERLOAD PROBLEM
I had the same problem. As soon as the volume reached about 24db it would go into overload. I was able to fix it by soldering all the connections on the larger power module. The one connected the the heat sink. When I took it apart there where several solder points that had come loose.
Oct 10, 2007 | Technics SA-AX540 Receiver
136 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
