How do i reboot my toshiba equium l40-17m to factory settings?
I do not have boot disks.
  • Shadow1989 May 11, 2010
    Do you have a recovery partition?
Toshiba s55-a5279 reboot select media. File abd push any key to reboot how can i restore to factory settings wit out using disk
Pres F8 just before it tries to boot. If the recovery partition is still there you will be invited to recover. If not download your OS and install a fresh copy.
Nov 29, 2015 | Toshiba Computers & Internet
I have a toshiba laptop equium a100 laptop want to restore back to factory settings how do i do this
The best option is get a restore disc from Toshiba, I've done this a few times and it is a very easy process. Once you have the disc just boot the laptop with disc inserted and away you go!!.
Look here :-
https://backupmedia.toshiba.eu/
Jun 27, 2010 | Toshiba Satellite A100-S8111TD Notebook
I am looking to reformat the hard drive (ie restore to factory settings) of a toshiba equium a60 laptop. However, I have no manufacturer disks so wondering if it is possible?
I've had a look at the the Toshiba website:-
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=Toshiba+Equium+7100S+&x=9&y=8
It gives the impression that this is quite an old system. That being the case, re-installing windows requires re-formatting the HDD.
But keep the URL above handy, it may help with drivers you may need after the re-installationt.
Apr 29, 2010 | Toshiba Equium 7100S PC Desktop
How can I reboot my Toshiba Equium A200-1V0 and start it as new.
If you are mentioning about 'formating' your laptop, then you can do it with either a bootable OS disk or the recovery CD that comes with your laptop.
NB: Formating the disk will lose all the data in the drive. So take necessary backup before you proceed.
Boot your laptop with the CD inserted. Make sure CD ROM is listed first in the boot option menu in BIOS. Boot from the CD and format and start installing the OS again.
Please come back and rate my solution if this turns to be helpful for you or also if you need more clarification. Thnx
Apr 02, 2010 | Computers & Internet
Toshiba Equium 2000 does not recognise USB keyboard
check bios settings and enable kboard usb settings is ok, save to cmos and reboot
Feb 18, 2010 | Toshiba Equium 2000 (PV1065E0-011FR) PC...
DVD ROM won't read disks . Toshiba Equium
YOU SHOULD GO THO TOSHIBA SERVICE CENTER AND YOU CAN REPAIR IT ON ANY COMPUTER SHOP
Oct 20, 2009 | Toshiba Equium 100 PC Desktop
I need to know how to reboot this toshiba laptop and do not know how to
First, try windows diagnostic. Depress F8 button before the pc boots to windows and select Restore to best known...If nothing happens, try booting to Safe Mode. If it works ok in that mode then you need to reformat your drive. Make sure you use the Restore cd otherwise some or all the features like sound, VGA, etc will not work. When the Restore disk is through, it will prompt for the OS. Simply insert it into the drive's tray and follow the instruction on the screen. Good luck
Apr 28, 2009 | Computers & Internet
I have a toshiba pd205 that i need to restore to factory settings and can't find any information in my toshiba books. I am not sure if i received disks with this or not
with toshiba, they used to have a partition (i think it was M ) where all the recovery can happen. you can trigger the recovery when the first boot the system and still in black screen , watch closely, itmight ask you to puch F10 or F11, for that option. once you reboot it u know what am talking about.
Apr 26, 2009 | Computers & Internet
Restoring factory settings
You can restore your laptop using a regular windows cd, formatting the disk and reinstalling the OS again. After that all the devices which the drivers are not included on the windows CD like for example; network, sound, video, you can download them from the manufacturer website and complete in this way the process to restore your laptop to zero.
Nov 15, 2008 | Toshiba Equium 3150M PC Desktop
I have a Toshiba M70 laptop. I want to revert to the factory settings and re-install Window XP. The Product recovery DVD ROM does not run any program but just has a large file that Windows does not...
you should be able to boot to that disk and begin the reinstall process. just put the disk in, reboot, and watch the boot process to give you a prompt similar to "press any key to boot from CD..."
That should start you install.
Jul 11, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
881 people viewed this question
David Payne
David Payne
