Question about Refrigerators
Indesit fridge freezer total no frost is making a clicking noise ans the internal lights keep going out same here and it is happening more and more often....
  • 2 more comments
  • mikenew Mar 04, 2009
    I have a loud clicking that comes on every so often and it is becoming more frequent. If it is left it eventually shuts off...
    the model number is cm03ff
  • mikenew Mar 05, 2009
    So is the advice here to seek out a professional?
    Blimey I could have done that in the first place
    the model number is Ban 12 NF (UK) T
    the clicking is at the top of the unit by the thermostat options where the circuit resides
    Scholar:
  • 165 Answers
Common frost free fridge parts... Compressor - this is the heart if the refrigerator, it pumps the gas around the refrigerator system tubing.
The condenser - this is the warm tubing, it gets warm from the heat removed from the fridge food and allows the warm gas to cool to be re-pumped back into the refrigerator.
The condenser fan motor - A fan device used to force air through a condenser to aid in the transfer of heat.
The condenser fan motor - not all fridge's have this, it is a fan that blows room temp air across the condenser ( hot ) tubing to help remove the heat from the condenser tubing and also helps the compressor run cooler. This fan motor also helps the defrost water evaporate and disappear.
The evaporator - This is the cold tubing, the gas is pumped into it as a liquid and the gas boils to remove the heat from inside the fridge. The heat/exchanger - this is the highway tubing that allows the gas to be pumped into the freezer and carries the cold gas back to the compressor. The large tubing section of the heat/exchanger is the suction line the smaller tubing soldered to the suction line is the capillary tube, this small tube controls the amount of gas entering the evaporator.
Evaporator - A part of the refrigeration system in which the refrigerant gas evaporates, absorbing heat from the surrounding area.
Cold control - this controls the on and off of the fridge, it senses temperature changes to do it's job. A switch that controls an electric current in response to changing temperature. More properly called a Temp Thermostat.
Defrost timer -  this is a timer motor controlled device, it will shut the fridge off and put the fridge into the defrost mode at a pre-determined time depending on make and manufactures. The timer also makes the fridge come back out of defrost and puts normal running back on. Defrost thermostat - this allows the defrost heater to heat up to a certain temp and then shuts the defrost heater back off.
The defrost thermostat can be found in the evaporator coils. This is a bimetal switch used to open the electric circuit to the defrost heater once a set temperature is reached. The defrost cycle will continue until the timer advances into the cooling cycle, however the heater will no longer be energized. This thermostat will reset to a closed position once a set colder temperature is again reached. May also be called a defrost limit switch.
The defrost heater - this is a electric heater imbedded in the evaporator coils, the heater melts the frost and changes the frost to water.
Defrost drain - the drain is suppose to carry the water that has been melted by the defrost heater away from the inside of the fridge to thecondensing tray ( the condensing tray is usually found under the bottom of the fridge ), a pan-shaped panel used to collect condensate from the evaporator during a defrost cycle. It is usually located above a condenser coil or atop the compressor. May also be called condensate water pan.
Drain trough - A trough-shaped panel used to funnel defrost condensate, from the evaporator coil, to the drain tube leading eventually to the drain pan
Evaporator fan - This is the fan inside the freezer section, it will circulate the cold air around in the freezer and blow the cold air from the freezer into the fresh food section, it also sucks the warm air from the fresh food section back into the freezer to be re-cooled. I have some samples of this air flow...back wall evaporator here...floor evaporator here...
Posted on Mar 05, 2009
  • 916 Answers
This fix it now article explains how to identify the problem as well as how to fix it: Click Here
Posted on Mar 08, 2009
  • Refrigerators Master
  • 19,396 Answers
The most common is that clicking noise on a fridge is coming from the start system on the compressor , and in that case this must be replaced. When it is the compressor start system you also get not enough cooling or cooling irregular.
On modern units clicking can also be caused by a jammed water dispenser or ice maker solenoid.
Some unit may also have an electronic board , with a protection circuit that can start clicking , but when that happens the appliance does not start at all.
Try first to understand if the noise comes from the ice maker of the dispenser, in that case test solenoid and inlet valve and replace the faulty part, if solenoid or valve are good but keep clicking replace control assembly.
If the noise is not from the parts above , then it is the compressor start system, in that case repace the start system.
You can find parts and diagrams for your appliance by entering the model number here.
  • 547 Answers
That if the defroster going on and off you can replace it but if it's still working I wouldnt worry to much thank you for useing fixya please rate me
  • 479 Answers
It seems an issue with the compressor relay switch so get it checked with a professional
Posted on Mar 04, 2009
    Brigadier General:
  • 8,619 Answers
Hi!
The problem is with the relay and its faulty, check it and if it is soldered fine then replace it. Please tell me the model no. for more information.
  • Rylee Smith
    Rylee Smith Mar 04, 2009
    You need to get the starter relay replaced. You can do it by ordering it from(If you are in UK)---
    Indesit refrigerator Repair
    Or you can call 0871 666 0719 (UK)
    Please ask for further clarifications.
    Thanks
    Rylee
    Genius:
  • 1,550 Answers
Check there is proper vent for fan .
  • SAM ANDERSON Mar 05, 2009
    The damper motor controls the amount of air flow that comes from the
    freezer side to the refrigerator side. This is an important component
    that needs to be working properly . I would recommend inspecting the damper & vent area
    for frost or ice build up that could be causing this problem. Check the
    door seals & make sure you do not have any air leaks.
The fridge is not cooling!! The motor and fan are both making noises as though they are working and the freezer is working perfectly. I have turned the thermostat up to the maximum but still no cool air.
If there is no cooling on the fridge but the freezer is cooling then the compressor and gas pressure seems good. So to check the set for blocks in the ducts we must shut off the fridge.Keep it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
The fan making noise can be due to frost build up .If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
Do not set thermostat up to max but keep it to normal .So try this test from the outside and make your observations so that we come to the solution.
Oct 09, 2010 | Refrigerators
Fridge is on but not cold. thermostat is on right temp but not fridge and freezer not cold at all
See if frost is on rear of freezer panel. posssible defrost heater ,relay, or timer quit.
Apr 30, 2009 | Refrigerators
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser won't shut off nor will the ice dispenser motor
Apr 01, 2009 | Electrolux Refrigerators
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is working but the firdge part is not cooling.
Apr 01, 2009 | Samsung Refrigerators
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Indesit fridge freezer not getting cold (2 years old)
I would first check to see if the evaporator in the freezer is all iced up. If it is thats whay you do not have any cooloing. And If that is the case you have a defrost problem and it is not short on gas. If you see only a few coils on the evaporator frosted up then you do have a leak in the system and my be covered under the manufactures warrenty.
Jul 14, 2007 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerators Logo
296 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
