Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
Help On the wgr614 v7 when trying to reset, held reset button in for 30 secs, after that orange internet light stays on and doesnt let you do anything else.
    Scholar:
  • 82 Answers
That means it hasnt picked up an IP from the modem.
Unplug the power to the modem and the router. Leave them off for a full minute. Pluge the modem in first , give it another full minute then power up the router. If you still have problems try another cable.
If you still have issues, Power off the modem and the PC and repeat the above process.Verify the PC is getting connection. If you cant connect then call the cable/DSL company.
If you can connect download the latest firmware from Netgear and flash the router.
http://kb.netgear.com/app/products/model/a_id/2589
Posted on Mar 05, 2009
Netgear WGR614v7 flashing light
Providing you did not do any software up dates and usually if you do this procedure will help you get back into the router .Even then this usually work for the most part.Good luck
Best way is do a factory reset.Press and hold reset button during this procedure ,do not release the button until you are finished and you will be back to factory default.
1)Hold button 30 sec.
2)remove power cord hold 30 sec.
3)plug in power cord 30 sec.
You should now be in default factory mode,good to go.
Nov 06, 2013 | NetGear WGR614 Wireless Router
I have ( WGR614v7 ) wireless router.1st thing i got the problem with internet connection....2nd thing is I've mistakenly change WAN IP...now i got huge problem. i couldn't inter the setup wizard . so...
Oct 26, 2013 | NetGear WGR614 Wireless Router
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Wireless internet wont connect
Go to windows logo
in search box type cmd
in black screen type ipconfig /release
when completed type ipconfig /renew
try again if still no go do the following
reset to factory default
press and hold reset button during the whole process and only release when completed.
1)press reset button 30 seconds
2)remove power cable 30 sec
3)plug in power cable 30 sec and then release.
You should no be set for 192.168.1.1
username admin
password is password
If all fails check to see if the box is checked for wireless
Apr 04, 2012 | NetGear WGR614 Router
Cannot restore factory settings
You need to consult a qualified Technician.
Apr 17, 2017 | NetGear WGR614 Router
Trying to either re-set Netgear or obtain password I set about 6 years ago.
username admin
Dec 25, 2011 | NetGear WGR614 Wireless Router
I recently reset my router too factory settings by holding the reset button for 30 seconds or so. Now that its back on the lights for internet are on but the wifi light isn't on and its not giving out...
by default wireless is turned off until you administer and set security. after a good reset it is off.
you must hard wire to the router and then browse it using its IP.
once you are connected then open a command prompt and type "ipconfig" hit enter it will display your IP the a subnet mask then the gateway. The gateway Ip is the routers number so enter that number in a browser and the follow below for setup screens. because you reset this the ID will be "admin and the password will be "password"
http://kbserver.netgear.com/pdf/wgr614v6_ref_man_20Apr05.pdf page 25 references what to do from there.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | NetGear WGR614 Wireless Router
Netgear Router WGR614 Problem, 1234 Lights Lit Orange, No Connect
Try resetting the Netgear back to the factory default and then configure the wireless setting.
Press the pinhole RESET button on the back of the Netgear until all the LEDs flash then connect a LAN cable from the computer to the Netgear open a browser and enter the configuration URL IP address
http://192.168.0.1
Jan 01, 2010 | NetGear WGR614 Wireless Router
Angel
In this case,we can do a power cycle of the router.steps to do a power cycle
1.unplug the router power adapter and then the modem power adapter if its a cable modem then we should also unscrew the coaxial cable wait for 10 sec and then screw it and now plug the modems adapter first wait fir lights to be stable and then the routers power adapter.now check the lights.
If power cycle doesnt resolve your issue then do a reset.restting a router is setting it to the factory setting so pls note the changes you have done in the netgear smart wizard page if any.
steps:
1.HARD RESET-you ll find a circular hole(reset button) at back panel of the router(see d chart on the router ).take a paper clip and press and hold for 30 secs and release it after 30 secs.
2.FUNNY RESET-If the previous step doesnt work,then we have do the funny reset.Here press and hold the reset button for 1 minute simultaneously plug and unplug the router 3 times.
Hope these steps solve your problem if not reply me and if this issue is solved pls rate me to improve my service.
Jan 06, 2009 | NetGear WGR614 Wireless Router
Router orange button
on the back of the unit is a reset button
Hold that down for 30 sec
that will completely reset the router back to factory defaults
turn the unit off for 15 min while the ISP's connection resets.
Then power back up.
you should be able to reach 192.168.1.1 via the browser thru the wired connection.
Then setup the system again.
the only problem is if your MAC was cloned by the ISP and that is the only connection they will let back on.
If that is the issue, please respond back
Jan 01, 2008 | Linksys Wireless-G WRT54GS Router...
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
220 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
