Question about GE Washing Machines
My GE wpsr3100w0ww washer won't agitate. It will fill and spin, but when it is time to agitate, absolutely nothing happens. The water just sits there. Then when the cycle is done, it will drain and spin just fine. When I turn the knob to the agitating cycle, it makes a clicking noise. Does it need a new timer?
  • 20 Answers
SOURCE: machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Posted on Jan 19, 2009
  • 72 Answers
SOURCE: Roper top load washing machine. Fills with water and then stops
Check out the drain pump, it is not uncommon stuff gets stuck in the impeller preventing it to do its work.
Also check out the drain filter and that the drain tube is not clogged. Very common causes of trouble in my experience and would give symptoms like you describe..
A good method to check if the output side is clear may seem a little gross but... take a deep breath and blow through the drain tube from the other end (taking whatever precautions you feel like).... It should be possible and if you can't, you know where the problem is.
Posted on May 21, 2009
mgprice
  • 744 Answers
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Posted on Jul 19, 2009
  • 57 Answers
SOURCE: The agitator will not spin
The problem will be in the pressure starter kindly check whether water stops after certain level and ready for washing,if it is OK means kindly check the wire connections from the operational panel to the motor, in most of the case the timer will not send signal to the motor for that kindly change the operational panel and check it
Posted on May 18, 2010
SOURCE: GE Washer WJSR2080V3WW will fill, spin and drain but not agitate.
The problem is the agitator coupler (about $ 7.00) simply pull straight up on the agitator - Give it a good tug. take the one bolt holding the coupler off - pull straight off. Replace the coupler and bolt (they are sold together). Line the agitator lines up with the coupler lines - when they line up it should go all the way down and snap back into place. and your done.
Posted on Oct 02, 2010
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
I have a GE washer model # WHDRR418GWW. It is about 19 months old. It stopped agitating and spinning. It will fill with water and the timer/knob will go thru the cycles. But when it reaches the washing...
You have what is called "agitating dogs" there are usually 4 of them at the bottom of the agitator. They have small grippers which lock onto the agitator and agitates. If the washer is ever overfilled or over time filled to heavy this will wear down the nylon teeth on the "dogs". The top of the agitator will spin off, you will see a bolt inside at the bottom, remove bolt and the agitator will pull out. Google "agitating dogs on washer. It will give you pictures for a better understanding. If the belt was broken the washer would not drain, because the belt turns the pump. These dogs are about $5 and honestly easy to install. Good Luck.
Dec 04, 2010 | GE WHDRR418GWW 35 cu. ft. Washer
Washer will not agitate but fills/drains/spins
Could be related to pressure switch which measures the amount of water in tub. Does it fill and then just sit there?
Nov 13, 2009 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
ck lid switch can be acessed by pressing clips at front edge of front anel and pulling panel off
Nov 20, 2008 | GE WWSE5200B Top Load Washer
Ge wvsr1060a2ww washer does not spin or agitate
first look to see if this is a belt drive. If not look for a coupler(round black rubber piece with three holes, three plastic fingers from both sides going in it) from the motor to the gearcase. The motor sit between the pump and gearcase, it will pump out, but not spin.
Nov 08, 2008 | GE WVSR1060A Top Load Washer
Washing Machines Logo
273 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
