Question about Whirlpool Dryers
Have a whrillpool Ler7647Q dryer, it's not spinning
The timmer stll working, there's heat no spin
    President:
  • 2,992 Answers
You probably have a broken belt, which is a common problem. If you are comfortable with using a screwdriver, you can change the belt yourself and save the cost of a service call. The belt itself is around $20, and you can get it from local appliance parts stores or from a number of places online.
One site with a very good illustrated procedure for changing the belt is here:
http://repair2000.com/wpoolbelt.htm
If you found this solution to be what you needed, please take a moment to rate it (fixyas are nice!), and thanks for asking here!
Posted on Mar 04, 2009
My whrilpoo cabriol up right washer will not drain an spin
you have a bad timmer
you can order a new timmer
and install it cheap
or call a repair man
Nov 14, 2016 | Washing Machines
Kennmore 110.22422. 100 hummms when reaching the spin cycle
your timmer button has given up replace the timmer and it will be fine
Jun 19, 2010 | Kenmore 22422 Top Load Washer
My dryer works (spins, blows air) but it won't hea...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Dryers
25 years old,top load. put on new belts 3 weeks ag...
Timmer may be bad. Bad contacts on timmer for spin mode. Check to see if timmer goes though cycle to end. Also check lid switch.
May 17, 2010 | Washing Machines
Kenmore front loader dryer will not start on it own-
please give more info,
does it spin but won't stay running?
when u set the timmer to start does the motor turn on at all hear any noises?
what was the last thing the machine did, before it went out that helps to
diagosis the problem easier thanks
Feb 01, 2010 | Kenmore 73952 Gas Dryer
Whirlpool Dryer, Heats up, but will not spin.
Thermal fuse , is the small white plastic piece on the blower box . That , keeps the dryer from running . Thermal cut-off , is the small thermostat on the burner (element) box , which would keep the dryer from heating .
Jul 31, 2009 | Whirlpool LER5636P Electric Dryer
Drier was working O.k . Timmer Stop working And so did the Heating. Does the Timmer control Temperature aswell.?
Yes, if the timer mech is damaged and, it will not rotate, this is cause the heating cycle to become inoperable. the time is responsible for initiating the heating command and the thermostat helps with the temp regulations. replacing the timer will restore the normal functions of your dryer.
Jun 18, 2009 | Whirlpool LER5636P Electric Dryer
The heating compenent works, but drum won't spin
Have you checked the belt? That's generally the problem when a dryer stops spinning.
May 19, 2009 | Whirlpool LEQ9858L Electric Dryer
The dryer heat works but the drum is not spinning.
Raise the top lid and inspect the belt. If it is broken, replace it.
Apr 12, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
