Question about GE 25951EE2 Phone
CALLER ID THE PHONE IS NOT SHOWING CALLER'S ID my caller ID on both my GE phones started at the same time...not all the numbers or letters in the caller ID are showing up......my model# is25951EE2-A is it fixable?
  • bellonline May 08, 2009
    I have the same model and it's doing the same, when phone rings the display shows NO DATA. I have caller ID and my reg AT&T wall mounted shows CID. My last CID on the GE brand was on 5/4/09. Tried pulling batteries to no good, still the same. Even tried switching phones and bases around. I find it weird though that the person before me wrote the same day mine went out, is this a coincidence or what.
  • Anonymous May 16, 2009
    test
I just got off the phone with a GE rep, they said to unplug all phones from the wall for 15 minutes, then remove the batteries and put them back in the opposite way they came out. That will reset the system and fix the problem.
If it does not fix it, you'd need to purchase new phones.
Posted on May 29, 2009
My caller id is not showing name or number of the
Since CID display to the phone comes from the Panasonic phone SYSTEM, you might try looking inside the cabinet to see if it has a caller ID card. The part ends in 93.
It also requires some programming. If you post your model number, I might have a CID card if yours is missing.
Carl
Dec 04, 2009 | Panasonic KX-T7731 Corded Phone
Caller ID posts incorrect name with number What
Some telephones, just like your cell phone, will show the caller-id name you have programmed into the phone-book memory. If this is the case, then the solution is an easy one, just change name yourself.
If this happens on every caller-id phone or box in your house, then you should call your phone company as there CNAME database might be corrupt.
However if this only happens on the GE phone you mentioned and there is no phonebook memory in it, then I suggest exchanging the phone.
Sep 03, 2009 | GE Lands Phones
I have three handsets and two of the phones caller id is not show
yes if its fading out .its possible that the battery is causing this.also other possibility is that the internal cicuit of the device is moistened or may be needs to be resoldered as some connections may be loosened up too. its a common problem and will get fixed once above things are checked 1 by 1. thanks.
Jul 08, 2009 | Uniden Cordless Phone
Caller ID??
the phone is not equipped to handle caller ID
Oct 17, 2008 | GE RCA 4-Line Speakerphone
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
Caller id display screen
I can't read my caller Id Screen numbers are disappering
Jul 27, 2008 | GE 25951EE2 Phone
Caller ID
Even at its factory defaults your Siemens handset should be showing the caller id after the second ring. Look at your time and date on the phone, if they are not accurate then the caller id signal is not coming through since when activated caller id will not only give you the caller information, but it syncs with the telephone companys clock too. If I were there, I would take a phone that is known to have its caller id working and plug it in your line and see if caller id shows up on it. If it does show caller id, then there is something wrong with your Siemens base. If it does not, then your phone company dropped the ball and caller id is not activated. Then I would take the Siemens phone to another line (neighbor or friend) that has working caller id and plug my Siemens into it and see if it shows up. Doing all that will isolate your problem, I guarantee it.
Jan 23, 2008 | Siemens Gigaset 4200 Cordless Expansion...
CALLER ID
the caller may have with-held their number, either as a one-off, or as a feature, or perhaps your phone company has a fault on their caller Id equipment.....does this happen with all calls, has it only just started happening ?
Jan 08, 2008 | Panasonic KX-T7730 Corded Phone
Caller ID not working in India
In USA, CANADA, telephone company uses FSK for Caller ID detection while Indian Telecom companies uses DTMF standard. this is the mismatch and reason for caller ID not working.
u need to purchase seperate caller ID for it.
Oct 28, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
GE 25951EE2 Phone Logo
242 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
